Trackson d4 question
Showing 1 to 10 of 39 results
Jw74
Send a private message to Jw74
Hi every one I am wondering if anyone can give me some info on this serial # 7U16108SFG The SFG part looked like some one stamped it on the tag it did not look factory stamped, what does the SFG mean? What year might this be? and what Engine ? This is a tractor that I am interested in and would like to know a little info about it. Thanks !
Thanks God Bless
Wed, Dec 3, 2014 1:46 PM
Tractor is a 1952 model with D315 engine.
SFG is a new one on me but I suspect it has to do with special gearing in the transmission.
Wed, Dec 3, 2014 2:34 PM
OzDozer
I've never seen SFG stamped on any Cat, but there's always something new to catch you out.
"SP" after the S/N indicates "Special Parts" that are installed on the assembly line. These were usually options or attachments such as lighting options, batteries and heavy duty generators, optional transmissions, and a range of other items too long to list.
The "SP" designation was discontinued in Dec 1946 for all factory-fitted options and attachments, except for special transmission and final drive gearing.
However, Caterpillar warned that the absence of "SP" as a S/N suffix after Dec 1946 was no indication that the tractor was a standard tractor, and it still could have "special parts" fitted.
"SPC-G" stamped on the upper right rear face of the steering clutch housing, on D8's, D7's and D6's of the 1940's and early 1950's, indicated "special low or high speed transmission gears".
This meant that a standard transmission could have optional gear groups installed, but there was no other markings to indicate such.
The transmissions with these gears fitted did not have any special part numbers or other markings to indicate the gear speed alterations, thus the markings on the steering clutch case were to warn repairers about them.
(SPC-G info - Service Magazine dated Feb 19, 1940).
Wed, Dec 3, 2014 4:29 PM
Dozer2442
Send a private message to Dozer2442
Reply to OzDozer:
The HT4 had no fifth gear and 2 reverses. SFG = Special ? Gear
Regards,
Dozer 2442
Thu, Dec 4, 2014 9:08 AM
Jw74
Reply to Dozer2442:
Regards,
Dozer 2442
thanks guys! I have not gone to look at it yet just seen photos but appears to be in decent condition they say the clutch needs adjustment and pony motor needs work so who knows what that really means. I looked at it again and I think it is actually SPG the p is overlapping the G and looked like a F
Thanks God Bless
Thu, Dec 4, 2014 10:09 AM
OzDozer
Reply to Jw74:
I seem to recall sometime in the late 1940's, Cat went over to using just "SPG", instead of "SPC-G" for special transmission/final drive gears - but I can't find any specific advice on the change, because I'm missing quite a number of Service Magazine issues from the late 1940's.
I would think that Dozer2442 is correct, the SPG refers to the transmission gear differences between the HT4 tractors and the standard D4's.
Thu, Dec 4, 2014 10:44 AM
Thank you received: 93
Reply to OzDozer:
great to see you back OZ.
here are copies of said SM's. Feb 19 1940 and Feb 20 1941.
So far have not found anything later except for an article on Special group Number Plates for D6,D7,D8, No6, HT4 and 583 in a Service Bulletin - Track Type Tractors - Nov 18 1955 now added to this list.
Thu, Dec 4, 2014 11:16 AM
Jw74
Reply to edb:
Thanks Guys here are a few photos. What do you think? I know it is tough to judge until I go look at it in person but looks to be in decent shape. Is the clutch adjustment on this HTD4 done in the same manner as my 5UD2?
Thanks God Bless
Thu, Dec 4, 2014 1:06 PM
Jw74
Reply to Jw74:
I particularly like the exhaust cover 😆
Thanks God Bless
Thu, Dec 4, 2014 1:12 PM
Jw74
Reply to Jw74:
for some reason I can not open those pictures ...
Thanks God Bless
Thu, Dec 4, 2014 1:14 PM
Jw74
Reply to Jw74:
sorry if you cant open these not sure what I am doing wrong
Thanks God Bless
Thu, Dec 4, 2014 1:16 PM
