Track rollers D7 3T
Track rollers D7 3T
Showing 1 to 9 of 9 results
mrsmackpaul
wondering what the track roller sizes should be I guess when new and when worn out ?
Is there some were on here I can look for this information
thanks for any help
Paul
Wed, Jan 21, 2015 2:09 AM
mrsmackpaul
Also can I get sealed for life rollers to replace these ?
Paul
Wed, Jan 21, 2015 2:11 AM
Andrew
Reply to mrsmackpaul:
Paul
How many rollers do you want.
When replacing only one or two you should measure the existing rollers and get a second hand one about the same dia...
I think in a recent post , Conservation bulletin ???????? Had a chart on roller sizes
Let me know what you need should be able to find something here.
will send you a PM.
Andrew Kennedy.....
Wed, Jan 21, 2015 3:36 AM
Thank you received: 39
Reply to Andrew:
will send you a PM.
Andrew Kennedy.....
New track roller diameter is 8.75"
100% worn is 8.00"
New lifetime roller assemblies if you can find them
Single Flange 8H3863
Double Flange 8H3936
All are out of production now but there are still some out there.
Wed, Jan 21, 2015 5:02 AM
Andrew
100% worn is 8.00"
Some photos of rollers
Wed, Jan 21, 2015 7:45 AM
Old 3T lover
100% worn is 8.00"
[quote="Old Magnet"]New track roller diameter is 8.75"
100% worn is 8.00"
All are out of production now but there are still some out there.[/quote]
Old Magnet, wasn't there a difference in bolt hole sizes in the collars? ...5/8" to 3/4" later? If you had the 5/8 bolts you had to use a 'filler'.
It's been well over 30 years since I bought any rollers for a 3T.
Wed, Jan 21, 2015 7:48 AM
mrsmackpaul
Reply to Old 3T lover:
100% worn is 8.00"
Andrew I had a look at the conservation bulliten and then chacked my rollers and the all seem fine before left to come down this morning talk about rain wet as all the way from Sarina to Miram Vale
Thanks for the help everybody
Paul
Wed, Jan 21, 2015 6:45 PM
100% worn is 8.00"
[quote="Old 3T lover"]Old Magnet, wasn't there a difference in bolt hole sizes in the collars? ...5/8" to 3/4" later? If you had the 5/8 bolts you had to use a 'filler'.
It's been well over 30 years since I bought any rollers for a 3T.[/quote]
My info on roller bolting isn't the best but based on the 4F262 lock that they used the bolt diameter is the same size throughout the production run. May change when trying to adapt later rollers as you say.
Thu, Jan 22, 2015 12:58 AM
Old 3T lover
Does that lock carry on through the 17A series?
I remember something about bolt sizes for the rollers.....I don't have senior moments any more, I have senior days.
Thu, Jan 22, 2015 3:30 AM
Yes, same through the 17A series. Changes with the D7E.
Thu, Jan 22, 2015 3:57 AM
