Track roller lubrication D4 7u
55HT4
Send a private message to 55HT4
I have a 55 7u ht4 #31435 Can someone link a fitting that I can use to lubricate the track rollers/top roller. Does someone make a fitting to attach to a grease gun/air driven volume compressor?
Here's a pic of the roller if that helps.[attachment=54553]track roller.jpg[/attachment]
Tue, Jul 2, 2019 11:23 PM
Those are filled with 30w oil not grease. No need to add unless leaking. They are a "lifetime" type roller. When the shell wears out then they can be rebuilt.
Wed, Jul 3, 2019 12:22 AM
55HT4
okay thank you
Wed, Jul 3, 2019 1:11 AM
They can be refilled with oil to perhaps prolong the life of the bearing. Takes a nozzle to stick in and fill from back out to front basically. I think OM posted the picture and info on the official tool recently.
OzDozer posted that he just poured oil in regularly on his not using the nozzle, just depending on rotation to redistribute the oil inside. He wasn't looking for a complete " lubed for life" fill that you would get with the nozzle.
The plugs can be very tight in my experience.
Most folks probably don't bother and just accept the designed life, but on old machines that have sat idle a lot of years I expect it would pay to refill them.
Wed, Jul 3, 2019 11:30 AM
Thank you received: 93
Hi Tea,
scans below is for said tool as used at The Dealer etc., also for how it is carried out.
Usually a few hits on the head of the plug with a suitable hammer and punch will ease the taper seat adhesion and allow you to unscrew the plugs a bit easier--there is a Cat socket tool that is made from quality steel that is used to get into the small square plug hole.
You can periodically check the oil level by simply easing out the plug to the last few threads and if oil starts to issue then we used to call the oil level OK.
If no oil, sometimes you may have suction due to temperature differences to last check, we used to ease the plug to the end of the threads and slightly tip the top of the plug out to see if oil is present.
Sometimes warm rollers can build a fair bit of pressure and spit out a carelessly removed plug and douse you with stinking oil. The oil tends to smell and turn black after a long time in service.
From memory, back in the day we used to dye the fill oil with red dye to help highlight leaks.
Wed, Jul 3, 2019 12:52 PM
