Track Roller Lubrication
Showing 1 to 10 of 12 results
cojhl2
Where do you guys get Track Roller Grease? I called Lubrication Engineers where we used to get it on the farm and they want over 200 $ for 35lbs.
ye Gads I cant afford that. What oh what can I do??
Wed, Jun 30, 2010 11:51 AM
bruce oz
Thank you received: 22
hello cojhl2 , i have just bought a 20liter drum from john deere here in Australia ,au$175,bp have 00 grease for about the same price,the 00 grease.
not cheap from any body ,
some manuals say you can used gear oil between 80w to 120w .
some other will have ideas on what to use ,bruce oz
Wed, Jun 30, 2010 12:07 PM
Thank you received: 35
Reply to bruce oz:
the local lube reps for The Dealer told us after they stopped making/supplying roller semi-fluid grease to simlpy keep adding and mixing in Cat 50w Transmission /Drive Train oil to ordinary grease until you get the consistency needed. It certainly is cheaper than other alternatives and works well.
Hope this helps.
Wed, Jun 30, 2010 12:27 PM
Reply to edb:
Hope this helps.
One old guy who lives near a Steam Train Museum told me he got something called Steam Head/Valve grease(?). Its in squeezable plastic bags so you can cut a corner off to squeeze it into your lubricator. Also other Farmer guys have mentioned Corn Head Roller lubricant(?). I haven't thought to ask when I stop at the farm supply but one of these days I'll need to as my supply of lube is running out.
Wed, Jun 30, 2010 6:44 PM
Reply to drujinin:
last year i bought a 35 lb pail of shell alvania EP00 grease for $77.70
Wed, Jun 30, 2010 8:41 PM
cojhl2
Reply to dpendzic:
Thank you everyone,, I got some good ideas here. One thing I have to keep in mind, this is not duty like we used to have where the tractor had to run for hours and hours maybe going 30-40 miles a day.
So, the mixing of grease is a good idea, also I'm gonna try to find some alavania. Of course it's probably increased in price also.
Thu, Jul 1, 2010 1:36 AM
B4D2
Reply to cojhl2:
This is the stuff I use. It fulfills the requirements of roller lube and is not ridiculously priced. Check with you rlocal fuel supplier. http://www.hwpetro.com/_fileCabinet/TexacoData/Multifak-HD.pdf
Fri, Jul 2, 2010 9:54 AM
Cysco
Reply to B4D2:
B4D2.....that is what I am using as well. I got lucky and found a distributor that had a bucket on the shelf and told me I could have it for $10.00 to get it off his shelf. Pretty good deal I thought.... 😊
Fri, Jul 2, 2010 4:40 PM
yancy44 mag
Send a private message to yancy44 mag
Reply to Cysco:
i got my roller lube at m,y local cenex bulk plant it was 00 and the cost for a 5 gal pail was 30 dollars
Fri, Jul 2, 2010 5:59 PM
chugwater crawlers
Reply to yancy44 mag:
The corn head grease you mentioned is available from John Deere dealers in a tube.
I think it is about $3.50 per tube. I use it. It works fine in the rollers. It a very thin soapy grease.
You may have to shop dealers. If they don't stock it they may want you to order a whole case. Most of the large dealers who sell a lot of farm machinery have it.
Fri, Jul 2, 2010 7:36 PM
the Farmer3
Send a private message to the Farmer3
Reply to chugwater crawlers:
I bought a case of the tubes of corn head grease from shoup http://www.shoupparts.com/
Sat, Jul 3, 2010 9:43 AM
