Track pin press
Track pin press
Showing 1 to 10 of 17 results
AARON LAOL
Send a private message to AARON LAOL
Been looking at track pin presses. The prices are all over the place even within vendors. What is everyone's thoughts? The cheaper ebay/amazon presses? Or the big $$$ professional presses? Has anyone had experience with the overseas built presses? This is something that we would use, but don't want to break the bank. Used ones seem very hard to find. Honestly, i'm more confused about this than when I started. Even finding somebody to press track pins is difficult and or expensive, in my area. We also have attempted to make one. We got a bit scared of the pressures.
So bottom line, we would like to find a budget track pin press. But I'm apprehensive about the lower price options.
Thoughts? Suggestions?
Cataholic!
Sat, May 30, 2026 6:33 AM
Thank you received: 140
Hi, Aaron LAOL.
What you might need to pay will depend a fair bit on the the sizes of the track that you want to work with - the bigger the tracks, the bigger the cost. To handle the really big stuff takes a LOTTTT of 'grunt' - which costs.
For the imported units, you might find some reviews on sites like Trustpilot. On-line searches for an individual make and model may also bring up some reviews.
If you can find a Caterpillar Service Tool portable hydraulic press with the tooling for pressing track pins, that may be your best bet. E-bay, Craigslist, etc..
Hope this helps.
Sat, May 30, 2026 6:58 AM
AARON LAOL
We are thinking that D2 to D6 size would be adequate. It looks like due diligence will be the way forward. Hopefully one pops up.
Cataholic!
Sat, May 30, 2026 12:14 PM
Thank you received: 288
There have been some folks that have tried the imported, online auction units offered with mixed results. I think 777Auctions (Atascadero, CA) currently has one of these available to bid on. A local member just bought a pair of them (not very much $) to try out. Best of luck to ya. JM
Sat, May 30, 2026 12:55 PM
Thank you received: 214
What are you intended uses? Just master pins or are you planning on complete job of turning Pins and Bushings? Do not be fooled by the designation of D2,D8, etc. Every track and every pin and bushing has the potential to require more pressure than others. Having a catastrophic failure of equipment is not something you want to experience! Proper equipment and setup are not options when it comes to life safety. THINK ABOUT the PRESSURES INVOLVED - same for pulling Sprockets, etc. (Yes - been there and never want to go back for seconds!) - cts
Sat, May 30, 2026 1:39 PM
AARON LAOL
In the immediate future we just need to shorten some chains. From 5 roller to 4. In the long run it may be turning pins etc.
Cataholic!
Sat, May 30, 2026 3:14 PM
Thank you received: 62
I came across this on another crawler site. Starts with a home made press that failed. Then moves on to a cheap foreign made press that did get the job done. It was very fast, but I believe place the press was from was in there.
Home made track press failure! - This job was a disaster.
Sat, May 30, 2026 3:25 PM
AARON LAOL
Thanks, I will take a look.
Cataholic!
Sat, May 30, 2026 3:28 PM
ChrisE
Thank you received: 41
Just watched the video. A bit of a circus. A fair bit of dodgy patch ups to make it work. Something typical of what the Aussies would do LOL.
Sun, May 31, 2026 11:29 AM
Hi, ChrisE.
Now, now, let'z not start getting 'racist' on this BB. LOL.
Sun, May 31, 2026 11:47 AM
But it was Ozzie's that brought it out where I could find it. But I think the tree and dry grass, along with it will be timed out in x months for not being ter 4 ,screams Caly Crazy Fornias.
Sun, May 31, 2026 8:56 PM
