Tow Start d4
Tow Start d4
Showing 1 to 10 of 20 results
mcbitchman
Send a private message to mcbitchman
Can an old D4 be tow started? I do appreciate all the help I've gotten from folks like Soapy and OldMag.. etc.... but now I'm totally stumped... Pony motor mag is not working and I can't seem to figure it out... even tried using a external auto coil and condenser... I have continuity through the pts. Today tried using a gas Briggs engine but apparently a five horse wont get it done.... so.... can one tow start a D4 and if so will a full sized Jeep four wheel drive p/u with a low range do the job? and What gear would I use to make it work? if it will anyway.... please help ,,, ole Chug Chug and I are bumming... thanks Doug
Sat, Jun 24, 2017 12:14 PM
caterpillar13
yes you can tow start it , you will need something heavier than a pickup to pull it , like a 60 hp tractor so you have the weight.
Sat, Jun 24, 2017 12:24 PM
mcbitchman
Reply to caterpillar13:
Ok so my p/u wont do it... Damn wish I could get my pony motor to spark.....any idea on where I might get parts for the mag
Sat, Jun 24, 2017 12:49 PM
rax200
Reply to mcbitchman:
Hi mcbitchman, have you given florin tractors a call as they have spare magy's both eisemann and the american Bosch ones
Regards
Sat, Jun 24, 2017 1:11 PM
8C 361
Thank you received: 12
Reply to rax200:
Regards
I have 2 D4 s that I park on a downhill and commonly roll start on compression. Use 5th gear. They usually start right up in a very short distance. On level land a full size 4x4 pickup might do it, it is worth a try.
I would try cleaning the points again. I just fixed one of mine the other day after 5 long years of compression starts. I got it stuck where I could not roll it.
Sat, Jun 24, 2017 2:27 PM
catsilver
Reply to 8C 361:
Its quite possible to start a D4 with a decent size 4x4, tow the D4 in top gear at walking pace -no faster, get it rolling on decompression, put it on full compression as soon as oil pressure comes up and then open the throttle. Towing any faster than walking pace is a waste of time and will only cause wheelspin.
Sat, Jun 24, 2017 7:47 PM
Thank you received: 281
Reply to catsilver:
Putting some ballast in the back of the 4x4 should help as well. A whiff of go juice possibly, unless you have plenty of straightaway to pull it.
Sat, Jun 24, 2017 10:10 PM
Paso Bob
My brother has an early RD-4 with a temperamental pony engine. We use his Ford 3/4 ton 4X4 to pull start it right out of the tractor shed. It pulls it without problem. 5Th gear and about 6 feet and it's running.
Sun, Jun 25, 2017 12:09 AM
captainhowdy
Send a private message to captainhowdy
Reply to Paso Bob:
take out the spark plugs and roll the pony over by hand. does the mag impulse or snap near TDC on compression? disconnect the on off switch to make sure it isn't grounded and check the wire from the mag to the switch to make sure it isn't bare and grounding.
Sun, Jun 25, 2017 12:38 AM
mcbitchman
Reply to rax200:
Regards
[quote="rax200"]Hi mcbitchman, have you given florin tractors a call as they have spare magy's both eisemann and the american Bosch ones
Regards[/quote]
Oh wow ,,, your RD4 is even older by serial number than the one I'm playing with .... my number is 4g4 637 w.... the w is for wide. it has the real wide tracks.... and no I've called no one because I didn't know who to call,. thanks Doug
Sun, Jun 25, 2017 2:57 AM
mcbitchman
Reply to 8C 361:
[quote="8C 361"]I have 2 D4 s that I park on a downhill and commonly roll start on compression. Use 5th gear. They usually start right up in a very short distance. On level land a full size 4x4 pickup might do it, it is worth a try.
I would try cleaning the points again. I just fixed one of mine the other day after 5 long years of compression starts. I got it stuck where I could not roll it.[/quote]
I'd read about a guy starting a 9 rolling it downhill. but how do you get the blade up? thanks Doug
Sun, Jun 25, 2017 2:59 AM
