Toolbar cylinder seals
Vance Nickerson
Send a private message to Vance Nickerson
Got the renewal worked out and now I'm on a quest for the seals or kits for the toolbar blade cylinder that would be on a D47U9640. Individual part numbers or kit. My parts book doesn't cover the blade or the 44 dual spool hydraulic system.
Vance Nickerson
Thu, Aug 17, 2023 9:07 AM
Thank you received: 288
Atta boy. I got some from my local HOLT of California store awhile back. If I can remember where by toolbar parts books are, I can try and look up the numbers for you.
Not sure if anything is in the members only section yet. If not, I should share for the benefit of others. JM
Thu, Aug 17, 2023 9:47 AM
d4e
Send a private message to d4e
Here is what my D4 tb book shows for the cylinders 1- 5k7054 seal, 1- k 7110 packing, 1-2h3917 seal, 1-1 h8128 seal per cylinder
Sat, Aug 19, 2023 1:46 AM
ChuckC
Send a private message to ChuckC
Reply to d4e:
I redid my tool bar cylinders a few years ago and I found everything I needed at a local hydraulic shop.
Tue, Aug 22, 2023 6:59 AM
Thank you received: 54
Reply to ChuckC:
when we asked a hydraulics service about rebuild the rams for our d4. they had no qualms about seals it was more the valving in the piston and that the labour charge would be quite high as a result.
Wed, Aug 23, 2023 4:56 PM
