toolbar 9U
toolbar 9U
Showing 1 to 7 of 7 results
u-joint
Send a private message to u-joint
building a loading dock so it can ship itself to the netherlands
[attachment=32632]gilbert toolbar 9U 003_003.jpg[/attachment][attachment=32633]gilbert toolbar 9U 010_010.jpg[/attachment][attachment=32634]gilbert toolbar 9U 009_009.jpg[/attachment][attachment=32635]gilbert toolbar 9U 011_011.jpg[/attachment]
Fri, Dec 18, 2015 12:20 PM
ag-mike
wow! I never seen one, other than a brochure page photo. Do you have brackets and tools for it?
Fri, Dec 18, 2015 8:37 PM
Thank you received: 62
Reply to ag-mike:
New twist on mounting a hydraulic tank,I understand the logic but in us can see big problems.My luck would be to have track come off a punch a whole in it.
Ag Mike you want one ? I have truions ram mount for track frame and arms with rams. No cross bar or blade.
Fri, Dec 18, 2015 9:32 PM
HOLLANDCAT
Send a private message to HOLLANDCAT
Reply to Ray54:
Hey John ,
Nice to see that D6 again , long time ago that i see that tractor .
How does it run ? , does it start up easy with the direct electric start ?
Hollandcat
Sun, Dec 20, 2015 7:04 AM
7upuller
Reply to HOLLANDCAT:
Hey John ,
Hollandcat
Hey U Joint,
Nice Crane... I should come visit, maybe you'll let me play with it!!! Merry Christmas to you my friend. Again you saved me. It's time to pull the salvaged 14-a pony off the shelve. Thank You!!!
Hey Holland Cat,
I'm jealous... You always get the nice stuff. If I come visit you, I might need to stay a while, you've got a lot of stuff... Lol
Glen
Sun, Dec 20, 2015 8:13 AM
HOLLANDCAT
Reply to 7upuller:
Hey U Joint,
Hey Holland Cat,
Glen
Hey Glen , you are more than welcome to vistit me .
Also I'm jealous to you ,,,,,,,,,, you live in the middle off the place where it all started , and were the nice machies are .
Again i wanted to come over with Johan this 2016 as i wanted some more things to fill a container .
Not sure if this is happen this year , as i have many things to do here .
I would love to see Mary-Ann with my own eyes .
Hollandcat
Sun, Dec 20, 2015 3:53 PM
Tugger
Send a private message to Tugger
Hollandcat
That's a nice 10B.I have 2 of them,currently unrestored.
Sun, Dec 20, 2015 10:41 PM
u-joint
Reply to Tugger:
HOLLANDCAT, yes the thing starts far better then with the starting engine. there is a plug on the intake above the air filter housing. screw the plug out, give it a quick snort of ether and hit the button. it does not turn over 3 times and its running. muddy mess here this weekend. set one block and that's it. I do have some leads on three 9U's in the Colfax area from D4harry. when I head to Moscow I will give them a call and see about sending you some pictures.
glen, first you have to let me drive the M41 through the drive through at McDonalds. then you get the chance to operate the Bucyrus Erie. Merry Christmas to you, the wife is well! all good! you hang around some fine looking women there. maybe I can get a date with one and we can drive the M41 to a drive in movie!
the tractor was used mainly for ag. the hydraulic tank is not an issue in this application. the blade has not had much use. I can assure you though if one was going to use the blade much you would move the tank. you cannot see anything on that corner when dozing.
tugger, I love the steering! that is a handy little guy to have around. when I first got it the guy had a 8 volt battery in it. so I always thought it to be a 6 volt system. did notice that it did not charge. that thing would start in 20 degree weather. battery finally gave out so I grabbed a 12 volt that was laying around as I needed to use the crane at that moment. noticed then that it was charging. it turns out it was a 12 volt system. this on top of someone putting on carbon core sparkplug wires and resistor plugs that were a heat range cold. the little BUDA is a born runner.
Mon, Dec 21, 2015 12:29 PM
