to mess with it....or not to mess with it...that is the question....
Showing 1 to 10 of 13 results
Hillbillybjopkr
Send a private message to Hillbillybjopkr
Hey guys....I know its been awhile...winter and work has kept the ole' D4 dormant for the last few months....been spending the last few days getting the pony motor kinda up to snuff....got it fired up today to do some adjustments to the carb.....like usual it runs on 3/4 to full choke.....messed around with the adjustment screws..no change....its only issue is that...running with the choke on.....I know about the passage in the bottom of the float bowl...and my carb doesn't have that 90' bellcrank in it....needle is part of that screw...haven't tried starting the main engine yet....but last year it had no issue starting the diesel....so....should I just let it ride till I HAVE to pull the carb for something...or say to heck with it...and pull the carb....and try not to ruin it getting that bottom passage cleaned....
Sat, Mar 25, 2017 6:23 AM
cojhl2
I'd fix that Carb. You will be happy Hillbilly. It's not hard to do. You will be so much happier and easier to get along with.
Sat, Mar 25, 2017 7:07 AM
Thank you received: 140
Reply to cojhl2:
Hi, Hillbilly.
If you decide to go the 'fickzit' route, this page may be helpful, depending on what carb you have.
http://www.acmoc.org/bb/showthread.php?21998-Starting-engine-carburetor-adjustment-(Late-modle-D-2-Zenith-TU4C-carb)
If not, I'd be surprised if there isn't somebody who has the info here.
Sat, Mar 25, 2017 7:35 AM
ag-mike
Hi, Hillbilly.
he ain't got that carb by stating "...and my carb doesn't have that 90' bellcrank in it....:usa2: Hillbilly do you know anyone with ultrasonic cleaner, i think thats whats it called. guys on the garage journal swear by it cleaning tiny passages. i ain't got no experience with it. i believe if it were me i'd use it 3/4 choked rather than pull those pia's off. good luck with ur project.:usa2:
Sat, Mar 25, 2017 8:10 AM
Mike Meyer
Thank you received: 6
Reply to ag-mike:
I just did my D2 carb a week ago and did not remove the carb from the pilot motor, if you remove the pilot governor it gives you good access to that cross passage under the carb bowl which I gently drilled out the solder plug and then explored the passage which on this D2 felt pretty clean, obviously I used plenty of carb cleaner and compressed air before bolting it all back together with a .177 air rifle slug punched back into the hole covered in some Loctite 515 sealant.
I'm not suggesting this is the proper way to do it but if you are time poor like so many then this quick fix can possibly save you a days work removing the firewall, magneto and carb then refitting it all and trying to time the magneto right, if it doesn't work all you have lost is the 5 minutes removing the governor, which you should be doing anyway to service it because after 50 or 60 years you can be confident the governors on these old Cats have never been serviced and are dry inside and need re-lubing with some ATF, the new gaskets are available ex Cat or can be made.
Mike
Sat, Mar 25, 2017 9:36 AM
Hillbillybjopkr
Reply to Mike Meyer:
Mike
well..as I thought..decided....to try and fire the diesel...no issues what so ever.....engaged the pony....pulled like a mule.....fired the diesel no problem...even took the ole girl for a couple laps around the property...damn it felt good lol....I just wanna get the pony running perfect..my OCD wants it right lmao......we are so far so good...
Sat, Mar 25, 2017 10:17 AM
Hillbillybjopkr
Mike
[quote="Mike Meyer"]I just did my D2 carb a week ago and did not remove the carb from the pilot motor, if you remove the pilot governor it gives you good access to that cross passage under the carb bowl which I gently drilled out the solder plug and then explored the passage which on this D2 felt pretty clean, obviously I used plenty of carb cleaner and compressed air before bolting it all back together with a .177 air rifle slug punched back into the hole covered in some Loctite 515 sealant.
Mike[/quote]
my adjustment screw is on top.....I little different than your pic.but not by much...ill.post some pics tomorrow in the daylight....
Sat, Mar 25, 2017 10:19 AM
Hillbillybjopkr
Reply to ag-mike:
idont know anyone with that type of technology....kinda a hermit.....I do all my own work lol
Sat, Mar 25, 2017 10:55 AM
Mike Meyer
Reply to Hillbillybjopkr:
Mike[/quote]
Well done on getting her running, that is a nice feeling for sure, I have 5 pilot motors hillbilly, a couple have the later crank style main jet adjuster, the others have your vertical screw type, the cross passage on the carbs is the same.
Sat, Mar 25, 2017 11:54 AM
Hillbillybjopkr
my next question.....what is a good starting point for the adjusting needles....if I remember right....I gave them 1.5 turns from seat....is this about right?
Sun, Mar 26, 2017 12:01 AM
Mike Meyer
Operators book says turn high speed screw one turn out from closed, turn idle screw out half a turn from closed
Sun, Mar 26, 2017 2:14 AM
