To Compress or Not Compress?
Showing 1 to 10 of 18 results
BigAgCat
Send a private message to BigAgCat
A month ago or however long ago it was I was starting my tractor. I get the pony rolling and snap the pinion clutch in place to get the diesel turning.
I decide I don't want to stand and wait for the diesel to get oil pressure, so I walk away for a few minutes with the diesel cranking without compression. I figure I would come back and turn on compression and have it crank for the obligatory 3-5 minutes or more necessary to start with compression.
When I finally go to my tractor, I pop the compression lever and the diesel already sounds ready to pop off. I open the throttle and the diesel fires right off.
So it leaves me wondering, does the diesel warm up faster without compression?
I will admit that I believe the weather outside was a bit warmer than the last time I started it.
I haven't exactly tried to officially experiment to see if the diesel warms faster without compression, but it is something that has me curious and something that does make some sense to me if it is true.
It seems like the life of a pony motor could be extended if it doesn't have to spend the majority of running time turning the diesel under compression.
Cat D6 5R
Sun, May 31, 2020 4:07 AM
bursitis
i usually don't need more than about 10 seconds of compression to start my d4 in cold weather. after cranking just until i get oil pressure.
Sun, May 31, 2020 4:15 AM
Reply to bursitis:
compressed gases always are warmer than uncompressed---simple thermodynamics where the work done energy is transformed into heat energy--PV=NRT
Sun, May 31, 2020 4:27 AM
BigAgCat
Reply to dpendzic:
Yes, but when the compression lever is engaged, all of the warmer gases will head out the exhaust on the exhaust stroke. With the compression released, the warmer gases can travel through the intake and into another cylinder. Thus, you are keeping warmer air in the engine for a longer amount of time rather than constantly adding cooler air.
Cat D6 5R
Sun, May 31, 2020 11:42 PM
The workload on the pony motor increases when I flip the decompression off/run, so that convinces me that more heat is being produced not only in the diesel cylinders from the heat of compression, but also going out the pony exhaust as waste heat. For those engines that have the heat exchanger in the intake manifold, it’s almost certainly heating up both the incoming air and the combustion chambers more than with the decompression on.
Mon, Jun 1, 2020 12:10 AM
gauntjoh
Librarian
Thank you received: 6
There is also all the heat generated in the common cooling system.
Mon, Jun 1, 2020 1:08 AM
kittyman1
Reply to gauntjoh:
how would heat created in the common cooling system help?? eventually it would.....but..............
wouldn't heat in the cylinder/head be better to support actual firing of that cylinder...in short order...
-how much time do you got....:tongue:
Mon, Jun 1, 2020 2:10 PM
How cold is your engine?
Below some temp, depending on what type of oil you use, warming the whole engine will make a big difference in actually getting it to run. Not to mention wear on bearings etc until it gets warmed up and oil is flowing well.
I have wondered if the occasional attempts by Caterpillar to have the pony motor share lube oil with the main engine wasn’t to get the oil warmed up faster. Of course, later models with oil to coolant heat exchangers warm the oil without the oil cross contamination problem.
Mon, Jun 1, 2020 8:30 PM
Thank you received: 62
A cheap no touch thermometer should tell the story of which way the head heats faster.
Mon, Jun 1, 2020 10:53 PM
BigAgCat
Reply to Ray54:
I am not sure it is reasonable to expect the pony to warm up the coolant enough to make a significant difference when starting. You'd probably have to run the pony for an hour just to get a significant temp increase in the coolant.
My thoughts are that the air doesn't all escape through the exhaust and instead may cycle back through the intake manifold with each stroke of the pistons. Thus, the warmer air continues to get warmer in the heat exchange tube instead of just completely fresh and cool air being sucked in and then blown out the exhaust.
A common oil system would be nice, but I think that would involve adding an oil pump to the pony.
My pony has a water pump, but I actually do question if the water pump is necessary considering that once you engage the starter pinion the diesel water pump starts pumping. So a person might be able to create a new oil line that drains into the pony sump and have an exit line that comes out of the pony oil drain and back into the diesel sump.
It's all interesting to think about.
Cat D6 5R
Tue, Jun 2, 2020 2:15 AM
D4Jim
Reply to BigAgCat:
The AL Vet is correct that the load on the pony from the compression tells one that a lot more heat is being generated by the loaded pony.
I typically run my pony longer on decom just to warm up the pony and get the oil circulating in the main. When the pony gets warmed a bit, go to full throttle on the pony, flip to compression for a few seconds and hit the main throttle. Usually less than 15 seconds on compression to start unless it is below 30 degrees F. If one thinks about it, the compressed air is heating the surface of the cylinder so that when the air enters and is compressed, it is at a temperature that will ignite.
That is a good idea Ray to check the head temp with a pyro. Now if I can remember to do that next time I crank up the D4 or 112. I use them all the time to check block and tranny temps on the green stuff.
Cats Forever
Tue, Jun 2, 2020 6:45 AM
