Timing the pony motor mag
mikedell
Send a private message to mikedell
Wanted to have someone confirm that the way I have the Mag installed on this pony motor is correct.
[attachment=23293]timing.JPG[/attachment]
Thanks, Mike
Sat, May 10, 2014 10:15 AM
Just like the service manual states.
Sat, May 10, 2014 1:37 PM
Thank you received: 77
Mike, that shot is good enough to put in the manual! : ) Now, just check you have solid core plug wires, new condenser, get the plug wires on the right plug, clean the points, check the grounding switch is open, and you'll have a big fat blue spark
Sat, May 10, 2014 5:56 PM
