timing a cat 22
timing a cat 22
notmuk
Send a private message to notmuk
Can anyone tell me the firing order of a cat 22? The serial #2f5868sp. Are there timing marks on the crank pulley or the flywheel behind the inspection plate? It has spark and compression and fuel😕there is a wico mag on it and a set screw is missing on the collar would that be enough to throw it out of time?🙄
thanks Doug
cat 15 project cat 22 dozer
Thu, May 29, 2008 11:16 AM
bruce oz
Thank you received: 19
hello notmuk,here is the pages for the timing of the 22 ,timing mark are on the front pulley on the right looking back.the firing order is 1-3-4-2.
bruce oz
http://www.angelfire.com/home/cat22/book/magneto.html
Thu, May 29, 2008 12:27 PM
