Throttle shaft D4-5T Pony
Showing 1 to 7 of 7 results
GOTSLOCO
Send a private message to GOTSLOCO
My carburetor overhaul project has gotten bit more involved. I need a new throttle shaft and bushings. After calling around it looks like if I want a new shaft I will need to make it. Outside of drilling the hole for the tapered pin at the correct clocking. Making one looks reasonably easy. Since making one makes no sense between the setup time and the minimum length of material I will need to purchase. The question is how many should I make? Or is there a source I have missed.
Contacted so far:
Carbsonly
The Carburetor Shop
Quinn Caterpillar, Salinas
Jim Zimmerman – Left message, waiting for returned phone call
As for the bushings they are not a standard size purchasable from McMaster-Carr. Making them looks like spending some time on the lathe. Pulling the old ones looks like tapping them 5/16 – 18 and pulling them with a sleeve and a nut and threaded rod.
My tractor is a D4-5T with a Zenith TU-4C, Tag No. 9790A, 8B3917
Geoff Tobin
TEN
D4-5T
Tue, Jan 23, 2007 2:21 AM
Thank you received: 60
I think I would try looking for another carb before building parts. At the rate I see pony motors being converted to direct start there should be plenty of candidates out there. Don't know what the market might be for new shafts???
Tue, Jan 23, 2007 11:18 PM
GOTSLOCO
I ended up making a new shaft. What I found in the process of getting to the point I decided to build the shaft was interesting. I found the bushings are available from CAT and so is a throttle shaft with a changed part number that is supposed to supercede the original. The bushings a fine but the throttle shaft I have some issues with. I first made the tooling to align correctly the stop assembly to the flat on the shaft when pressed together. The plating on the shaft looked to be a nice gold as if the shaft were brass plated. When I drilled the hole for the roll pin to stake the alignment I found it was not plated but brass. Thus a new steel shaft, like the original. I did take advantage of the dimensions I could take from the new shaft as well as the original and a “good” one I received.
I made the new shaft from a length of 1/4” oil hardening drill rod. The screws that hold the butterfly on are 5-40 and one does need to ream the bushings to size for the new shaft.
I made a drawing for the shaft and milling tooling. I can e-mail or post depending on interest. I did not make a drawing for the assembly fixture but can describe the procedure to make one using the old shaft as a pattern. I would not describe this as difficult project if you have access to machine tools but I doubt I would want to pay someone to do the work.
Below are some pictures of the process and one of the D4 and some other projects.
I have the carburetor reinstalled on to the D4 but have not been able to get the pony to run at high speed. More adjustments to the carburetor are required. More time once it stops raining for a while. At least I found the magneto works.
Part Nos.
Shaft: Original: 9B4977, New: 160-5208 -- Brass
Bushing, Stop side: 9B4783
Bushing, Blind side: 9B4779
Geoff
Thu, Mar 1, 2007 1:52 PM
Reply to GOTSLOCO:
Part Nos.
Geoff
Good pictures and good stuff. Thanks for posting.
My only concern would be using the drill rod which I find rusts quite readily.
I think I would stick to the brass or maybe a stainless.
Thu, Mar 1, 2007 10:56 PM
GOTSLOCO
I will agree with you on the use of stainless shaft. The material I used was material I had. I can see some advantage to stainless. I am not that familiar with the availability of turned, ground and polished stainless shafting but it is worth investigating.
The reason brass is not the correct for this application is fretting. The failure mode of the original shaft was wear all the way around at the brass bushing on the stop assembly end. There was also a groove worn into the shaft by the spacer washer.
In general a properly designed shaft and bushing combination are done when the shaft is significantly harder than the bushing. The can be seen by the differences in the coefficients of friction between steel on brass and brass on brass. Machinery’s handbook shows the coefficient of friction for steel on brass as .35 (clean) and Mark’s Mechanical Engineers Handbook shows a coefficient of friction for brass on brass of .88 (clean). For comparison Rubber on dry pavement is about .88. The concept of using a brass on brass combination in what amounts to an un-lubricated state, not a desirable combination.
If I were to remake the shaft I might look into stainless.
Geoff
Fri, Mar 2, 2007 1:23 AM
Reply to GOTSLOCO:
Geoff
You must be another "Mechanical Engineer" (so am I) from Cal Poly to.
I wouldn't worry about the coefficient of friction on a shaft that size and only used as linkage. There are also some pretty neat plastics available for bushings.
Can't really knock the brass either. (only lasted some 50 years. LOL)
Either way, steel equals stuck due to corrosion, think that is concluded.
McMaster-Carr has the precision ground ss rod starting at 1/8" dia. (not sure what the throttle shaft dia. is)
Neat project😄 😄
P.S. What is the GOTSLOCO company??
Fri, Mar 2, 2007 2:12 AM
GOTSLOCO
Neat project😄 😄
The original shaft was steel. The replacement I purchased form CAT was brass.
The tractor has few hours on it relative to its age I don't understand the shaft wear at all.
I am and engineer by training, BS Agricultural Engineering, Cal Poly SLO, BS Mechanical Engineering CSU Chico.
I no longer work in engineering due to the changing nature of design in the last twenty years. I saw the changes CAD would make but was not in the right place. I worked for 2D AutoCad company that refused to up grade in a world that expects 3D Solid modeling and won't train.
I use my engineering background for my hobbies restoring trucks, tractors, and Trains.
http://sprr.calpoly.edu/index.html
GOT is my initals
SLOCO is my location
Geoff
Fri, Mar 2, 2007 2:39 AM
Reply to GOTSLOCO:
GOT is my initals
Geoff
Thanks for the info.
Yes, the world of Engineering has sure changed. We don't do much anymore.
About the only Mechanical area booming is HVAC. Shame to waste all that training. Glad I'm retired and had a good ride😄
I believe it's the constant vibration that kills the shafts and bushings.
Fri, Mar 2, 2007 2:56 AM
| Kingaroy, Queensland
