Thitry serial number
Showing 1 to 6 of 6 results
BodieHunter
Send a private message to BodieHunter
Hi
Anyone have any pictures of where the serial numbers are on a thirty the rear fenders are gone along with the brass plates or have any idea how I can get a rough year built
Thanks Bodie
Fri, Jun 19, 2020 3:49 AM
Jeff M.
behind the gear shifter on the transmission cover
Fri, Jun 19, 2020 7:33 AM
janmeermans
Reply to Jeff M.:
But not always. I have looked on several which had the brass plates missing and no stamp showing where Jeff indicates. I think some were stamped and others not. I stand to be corrected but that is my experience.
JanM
Fri, Jun 19, 2020 11:47 PM
chuckb
Reply to janmeermans:
JanM
some times on top of the flywheel cover the older 30's had the snakepit exhaust manifold and the small track recoil springs some times a casting date
Sat, Jun 20, 2020 12:59 AM
Mike Meyer
Reply to chuckb:
Look behind #4 cylinder on top of the housing, mine has a date stamp there.
Sat, Jun 20, 2020 4:03 AM
BodieHunter
Reply to Jeff M.:
Jail this be a serial number or a date stamp can you post a picture of where it is I’ve found a number behind back cylinder looks to be a date
Sun, Jun 28, 2020 10:28 PM
BodieHunter
Reply to BodieHunter:
Found this number
Big number on top 50
Then as below
0 or 9
12
28
Sun, Jun 28, 2020 10:31 PM
