Thirty 6G Electric Start Conversion
DavidG
Send a private message to DavidG
I have a Thirty (6G series, very similar to an R4) and am thinking about converting it to electric start. It does not have a ring gear on the flywheel. Can a ring gear be put on the present flywheel and if so, where can I get one? If I get past that hurdle, are starters available and where can I get one?
Sun, Oct 28, 2007 9:37 PM
R4catkid
Send a private message to R4catkid
if you can get a ring gear, I have a starter I might part with...if your interested..
Thanks, -R4catkid
Fri, Nov 16, 2007 8:06 AM
DavidG
Reply to R4catkid:
Thanks, -R4catkid
I would probably be interested, if I can get a ring gear. Also I still don't know if I can put the appropriate ring gear on the flywheel I have or if I need a different flywheel. Can anyone provide that info?
Mon, Nov 19, 2007 8:07 AM
| Kingaroy, Queensland
