Temp Gauge not working....
D6c10K
Send a private message to D6c10K
Noticed the temp gauge wasn't coming up on my D6c the other day so yesterday I pulled off the dash cover to see what was up. As usual there was a mouse nest in among the wires but I didn't think that was the problem since the temp gauge isn't electic.
After taking a closer look I could see the mouse had chewed the plastic covering off the copper line to the temp gauge, but that shouldn't hurt anything. Must have been a determined mouse because it had also chewed the insulation off four wires, one of which was to the amp guage.....when I started and ran the machine it must have contaced the temp guage line and shorted.....the arc burned a hole in the line, so now I get the fix wires and buy a new temp guage/line assy.
No way to make the dash mouse-proof....only thing I can think to do is put a few poision blocks in the dash and hope they get sick before they chew the wires again.
Fri, Jul 26, 2013 9:00 AM
biggastractor
I put little Dixie cups full of moth balls wherever I think they are likely to make a home. Over the years this has always worked for me.
Good Luck
Biggastractor
Fri, Jul 26, 2013 11:08 AM
Feed cats around the farm, only varmits we have are larger ones, racoons and skunks mostly (they're probably drinking the milk we put out for the cats:lol)
Fri, Jul 26, 2013 12:09 PM
Constant battle here with critters, we live out in the sticks and any shelter is a home for something. Wood rats are the worst, chomp right through the wires, hoses and any plastic, rubber, and even the wire mesh in the house foundation vents. Any vehicle parked for more than a day needs to have the hood left up or there are occupants. I run a trap line 24/7 but still can't keep up. Going to try the bucket of water with soda bottle on a shaft smeared with peanut butter next. Hear that works pretty well.
Fri, Jul 26, 2013 10:06 PM
D4D83J
Send a private message to D4D83J
Old Magnet, tell us more about the bucket of water trick, these vermon are eating our trucks right down to the frame rails out here. Another thing that works well is a plastic 5 gallion bucket half full of water, they climb down to get a drink and can't get out and drown. I'm setting out half a dozen buckets today bacause this year the mice and packrats are worse than they have ever been.
Fri, Jul 26, 2013 11:11 PM
ErnieinTucson
Send a private message to ErnieinTucson
Reply to D4D83J:
Hi all
I use pine sol cleaner for pack rat control, seem to work well!
Does any one have information on how to adjust pinion on a RD6 Serial 2h1455. How do you get to it, as its under the diesel tank? It will not stay latched.
Ernieintucson
Sat, Jul 27, 2013 12:58 AM
Reply to ErnieinTucson:
Hi all
Ernieintucson
D4D83J,
It's a variation of what you describe.
5-gallon bucket partially filled with water.
Take a 2-liter soda bottle and run a rod throught the cap and bottom and through the bucket walls.
Smear peanut butter on the soda bottle for bait.
Provide some sort of ramp for the critters to get to it.
When they jump on the bottle it rotates and dumps them in the water where they drown.
Sat, Jul 27, 2013 1:12 AM
Mike Walsh
D4D83J,
[quote="Old Magnet"]D4D83J,
When they jump on the bottle it rotates and dumps them in the water where they drown.[/quote]
http://www.lolbrary.com/post/44323/redneck-mousetrap/
Sat, Jul 27, 2013 11:53 AM
Reply to Mike Walsh:
Yup, that's it....except I'd mount the bottle a little furthur down the bucket.
Sat, Jul 27, 2013 9:20 PM
| Hartley - South Australia
