Tag on Engine
Tag on Engine
Mike Hudson
Send a private message to Mike Hudson
Hello Folks I have a tag on the right side of the engine on my d2 caterpillar.  It says .030 rod and main.  Am I safe to think it was overhauled with that spec.  Thank you. Mike Hudson
Mon, Oct 30, 2023 6:47 AM
D4Jim
AS an opinion it may be correct or it may not. The only way for certain is to check each rod and main individually. I have seen rebuilt engines that have different regrind diameters within the same block. Then again it may be a professional job with all diameters agreeing with the tag. .
Cats Forever
Mon, Oct 30, 2023 7:45 AM
| Kingaroy, Queensland
