Swapping 955 undercarriage
Showing 1 to 10 of 15 results
56Cat
Send a private message to 56Cat
I have a 58 955, the undercarriage is shot, sprocket, pins and bushings are extremely worn. I have a 1956 955 with good undercarriage. After looking at the tracks and parts manual the 58 has a different undercarriage system compared to what's in the manual and on the 56. 56 serial number is 12a1408, 58 is 12a4697. The 58 has track tensioning cylinders, the 56 has springs, and the bottom inside rails on 58 are longer and come under final drive as opposed to the 56 which are shorter. Can some one advise why the undercarriage is different and would it be an easy change out or would an engine swap be easier?
Tue, Feb 16, 2016 11:42 PM
Thank you received: 50
Sounds like someone has played mix and match. By your s/n's the undercarriage should be the same with the change to D6 undercarriage components coming in at s/n 12A5793. Either way if the whole undercarriage assembly fits one, it will fit the other as well. Sprockets will also need to match the swapped undercarriage.
Nothing is easy working on a loader.
Wed, Feb 17, 2016 12:07 AM
56Cat
So what possible undercarriage would be under my 58? Would it be easier to change sprockets or whole final drive assemblies?
Wed, Feb 17, 2016 10:35 PM
Reply to 56Cat:
I have no idea what you have for roller frames. Nothing I know of has inner frame rails that extend past the final drives. Maybe some pictures would help with identification.
As far as sprocket vs final drive assy change out you get to choose between sprocket pulling equipment or lifting equipment to do the job.
Pulling the sprockets would at least let you check out the condition of the splined hubs, the sprocket fit to the hubs and the bellows seals.
Wed, Feb 17, 2016 11:08 PM
catsilver
The later 12A with track guiding guards also had a guide on the inside going back part way under the final drive, but it could also have been added by a previous owner some time in the past.
Thu, Feb 18, 2016 12:47 AM
56Cat
Reply to catsilver:
Thanks, I will post pictures next time I get a chance.
Thu, Feb 18, 2016 10:20 AM
56Cat
Reply to 56Cat:
Can I cut the good sprocket off and reweld on the other machine, swapping out track also? Or would I be better off buying new sprockets?
Thu, Mar 10, 2016 9:38 AM
rmyram
if the one machine is strictly a parts machine, then you can cut the good sprocket rim off and weld it on the other machine and swap the track, might want to swap out the rollers as well. it has been done many times by others on the forum that have a good runner and a machine with good undercarriage for parts. on a loader machine, it is easier to work on undercarriage then it is to swap the engine.
there were some good conservation mabulas uploaded and stored in the technical archive, i think Josh put them up? someone will help out here. Mike Myers did this exact think on an old 2h RD6 while the sprockets were still on the machine. Not sure if that story is on this forum or the ACME forum, had very detailed pictures.
Fri, Mar 11, 2016 11:30 PM
old-iron-habit
Reply to rmyram:
[quote="rmyram"]if the one machine is strictly a parts machine, then you can cut the good sprocket rim off and weld it on the other machine and swap the track, might want to swap out the rollers as well. it has been done many times by others on the forum that have a good runner and a machine with good undercarriage for parts. on a loader machine, it is easier to work on undercarriage then it is to swap the engine.
there were some good conservation mabulas uploaded and stored in the technical archive, i think Josh put them up? someone will help out here. Mike Myers did this exact think on an old 2h RD6 while the sprockets were still on the machine. Not sure if that story is on this forum or the ACME forum, had very detailed pictures.[/quote]
Seems to me there was a post a while back about a fellow using 10-24 or something similar screws and washers to hold the welding grove spacing and alignment until he got the replacement sprockets tacked in place on the machine.
Sat, Mar 12, 2016 4:42 AM
56Cat
Reply to old-iron-habit:
Thanks, I'll try to look the post up
Sat, Mar 12, 2016 10:33 AM
56Cat
I have search up and down. Unable to find the archives.
Sat, Mar 12, 2016 9:56 PM
