Support Bracket -#44 hyd unit w/4pipes
ubucat
Send a private message to ubucat
I have bracket that I don't know where is goes on my D4 7U with # 44 hydraulic unit and 4 pipes to the rear. I am sure this bracket is to support the rear of the pipes, but it was not on when I got the cat. It clamps to 2 pipes and is about 18 to 20 inches long and has one mounting hole in the opposite end from the clamps.
Sun, Feb 21, 2010 12:27 AM
ubucat
I thought maybe pictures would elicit more response. How about it 7Upuller, does yours have this bracket?
Sun, Feb 21, 2010 8:10 AM
7upuller
Reply to ubucat:
Don't recognize that bracket, not on either of my two scraper D4's. Sorry I couldn't help-glen
Sun, Feb 21, 2010 9:44 AM
Reply to 7upuller:
What ever it is it ain't factory😕 😕
Sun, Feb 21, 2010 9:51 AM
7upuller
Maybe it came off a tongue of a disc holding the hoses up???
Sun, Feb 21, 2010 10:25 AM
ubucat
Reply to 7upuller:
7upuller- It does look like a hose holder from a tongue alright. I couldn't figure out where it went, but it is painted cat yellow. The right hand or outer set of pipes are loose at the rear and will break over time if not stablized, so I thought maybe it was for those. I quess I can hose clamp them to the inner set which are bolted solid.
Thanks for the help.
Sun, Feb 21, 2010 12:47 PM
