Stump yoke?
Stump yoke?
Showing 1 to 10 of 27 results
Cat boy
Send a private message to Cat boy
Hey guys, while I was clearing in the woods I came across my great grandfathers old scrap pile. Just a random assortment of ruined truck frames and dozer pads and other junk iron. Then I saw something that fought my eye. It looked like a miniature V shear blade, I mean small! Seems like it mounted on the inside of the roller frame. Has a long round pole like a hay spear (bigger) sticking out front and a busting edge like a wood splitter on it. Asked my grandfather what it was and he said it was a stump yoke for a D69U. He said it was used when people harvested fatwood in the south. Seems there was once a big market for lightered knot stumps from the 60s to late 80s in Mississippi. After doing more digging I found out my great grandfather, his 4 brothers and every family in my area once all owned D69Us and used them for stumping. Has anybody else heard of a stumping yoke?
Wed, Jul 24, 2013 7:36 AM
I've seen like a huge moldboard style plow that would dig and cut stumps.
It was tree size limited though.
Can you get any photo's of this piece of history?
Wed, Jul 24, 2013 6:36 PM
Reply to drujinin:
Like this? Take down any size tree.
Thu, Jul 25, 2013 1:12 AM
Maybe one of these?? Blade mounted
Seems what your describing is different, picture would help.
Thu, Jul 25, 2013 1:49 AM
BillWalter
Back in 1957, I went with a seasoned field mechanic over into Mississippi to pull a transmission on a 9U D6 stumper. This company had several units and they dug out pine stumps for making turpintine.
They had inside mounted push arms goung out to a splitter and a rooter. They would hit those stumps in 4th gear and drop the rooter just before hitting the stump and while the tractor was still moving, pull on the 25ccu and lift the stumper, all the while the operator would brace his left foot against the dash board. This was done so often, the edge of the dash was as sharp as a razor. Reason for pulling the transmission was because the top shaft was broke. Those field men had found that the transmission could be pulled without removing the oil clutch. We had a made up top shaft so we just exchanged and slipped the transmission back in. These stumpers had no dozer blade. Just a spliter and a rooter about 18 inches wide. A truck with a boom loader would come along and pick up the stumps.
Fri, Jul 26, 2013 8:24 AM
Cat boy
Reply to BillWalter:
Bill hit the nail on the head. That is exactly what I'm talking about! My grandfather told me my great grandpa would have that dry clutch so tight you could barley pull the Handel back, he said it was like that so when ya hit the stump in 4th gear the momentum from hitting the stump would make your left arm throw the clutch out. Theses ole stumpers were a different kind of man, I can't wait to run one of these! Also do you think a 9U could handle a KG blade?
Fri, Jul 26, 2013 12:16 PM
Reply to Cat boy:
D6 9u is to light for a kg blade a D6D would be good.
Sat, Jul 27, 2013 9:19 AM
Cat boy
We have a few D6Ds and only 2 of them are worth a crap. Seems like the ones without the pre combustion chambers just don't make enough power to push a V blade. I personally use a D8 14A or a old D9G direct drive xof or shearing with a V blade. My main rake dozer on my crew is a direct drive D6C, iv run a KG blade and I kinda like them. But I can do more work with a Vblade. Was just wondering cause I need something to play with hahaha
Sat, Jul 27, 2013 10:25 AM
d2dan
Send a private message to d2dan
Reply to Cat boy:
had to look up fat wood . found lots of stuff about making turpintine and pitch and or rosin.neat i'm going to cook me some stumps now.
just for the record i will not be hitting a stump in 4th gear ouch!
Mon, Jul 29, 2013 10:17 AM
Cat boy
Reply to d2dan:
Well I still have this girl for stump related things and mass production clearing hhaha. I still like the idea of how these old timers used to do this, a completely different breed of man back in those days.
[attachment=18743]image.jpg[/attachment]
Thu, Aug 1, 2013 10:37 AM
Reply to Cat boy:
Either stand up on the Hood and shoot photo down or stand on step ladder in front and shoot photo of that blade.
It looks Nasty!
Better yet, raise it to a height where it can be seen in the rear veiw mirror of a car, photo it through the mirror.
If it looks like I think it will, submit it to Hollywood as the next killer dozer movie star! 😆
Thu, Aug 1, 2013 6:01 PM
