stuck in 2nd gear
stuck in 2nd gear
Jon
Send a private message to Jon
I need help with a early D7 that is stuck in 2nd gear. I now these tractors lock the shift forks when the clutch is engaged, but little else. any tricks? Jon
Mon, Sep 6, 2010 10:31 AM
What serial number is it, or at least what series?
Look beneath the floor plates for a linkage between the main clutch lever and the transmission. Could be internal in the clutch housing, but on most old CATs it's external. Just make sure the pins etc are in it to start with.
Mon, Sep 6, 2010 10:44 AM
Jon
Early D7 same as late RD7, clutch lever linkage is all connected. I pulled the shift lever the right shift fork is locked forward.
Mon, Sep 6, 2010 10:57 AM
Reply to Jon:
If it's not interlock adjustment it's time to pull the side cover off the transmission and see what's going on with the cam, springs, plungers, etc that make up the shifter interlock mechanism.
Mon, Sep 6, 2010 10:47 PM
Jon
that was simple, thanks for the help. Jon
Tue, Sep 7, 2010 7:09 AM
