[quote="Mike Meyer"]Hello, have you tried adjusting your steering levers? If you look forward of your two bolts a few inches you will see the 2 nuts you tighten to adjust your levers, that should give you more room on those two bolts, there will be a split pin, or bit of wire securing those nuts.
regards
Mike[/quote]
Thanks, Mike for the suggestion. Right now I don't need to adjust the clutches, but will keep that in mind for the future. I was just concerned that the clutches must be worn. Checking the thicknesses however, indicates that they are fine. Both clutch packs are around 2 5/8" thick, which appears to be fine. While I have the final drives off I figured I'd ask if I need to do anything to the clutches. I am a little concerned, however, that there may be a bearing problem with the left side as I can move that adjuster forward and back a fair amount, and see the yoke move when I do that.
BTW, I spent my R&R from Vietnam in Oz, and really enjoyed it. I stayed at the Hotel Wentworth in Sidney. That was very nice. Ray
Hi Ray,
if the release bearing cage the yoke lever connects to is not moving when you move the yoke lever then the bearing is likely OK.
The for and aft movement may be from wear at the ball pivot or steel bush at the bottom of the lever--fulcrum point, in the main case.
Your adjustment bolt positions do not indicate this. There is normally some side play of the yoke to the bearing cage but naturally this should be about the same each side.
Units with a grease update--later D2 etc have an O-ring each side of the bearing cage, on the bolts that the yoke pivots on, if these O-rings were ever fitted in the past by someone who did not understand they were not used on oil lubed units, they could give a false wear indication if one side did not have them--I am just supposing here as a possibility not an actuality.
If you can determine that the bearing cages, not the yokes, each side have about the same movement then there maybe no problem---the bearings used there are thrust bearings and usually have extra looseness to them due to their design--- There maybe just some hangup with the linkage etc on the side with least movement.
PS
I took my R&R in Singapore as I knew if came back to OZ for it I may not be found to go back--nevertheless Singapore was a great place to visit--and cooler!!!
Met a lot of your fellow countrymen there too and had a great time.
