Steering Clutch Specs
BELLY
Send a private message to BELLY
Does any one have the thicknesses for a D4 7U series steering clutches
Im looking for theses measurments Max & Min for a traxcatvator D4 ser
The only no>s I have are 3 and & 16ths normal to 3 and 5 /8ths maximum ?????
Tahnks to all, Rob
Fri, Aug 5, 2011 7:05 PM
Thank you received: 62
The minimum is in the Servicemen Reference book,but the old Cat books never give the new dimension.I think someone has gathered that information and shared it here before.Hopefully someone with better memory or better computer search skill will share.
Ray
Fri, Aug 5, 2011 9:09 PM
ol Grump
What I've got for the D4 steering clutch pack is 3 7/16" new and 3 3/32" time to replace. I don't have books on the loader so it might be different. Maybe someone else can chip in here to verify?
Fri, Aug 5, 2011 9:11 PM
Thank you received: 63
The published spec is actually 3-3/32 in. minimum and 3-7/16 in. average new.
It has been found that in some cases you can fit up to 3-5/8 in. new.
Fri, Aug 5, 2011 9:13 PM
DDDfarmer
Send a private message to DDDfarmer
hope this helps.
http://www.tractorparts.com/spec_sheet.htm
Sat, Aug 6, 2011 12:29 AM
