Steering clutch and final drive fluid
hdroadkingc
Send a private message to hdroadkingc
What's the best fluid to run in both. I have read that SAE 30 or 80w-90 gear oil will work.
Sat, Jul 30, 2011 6:14 PM
Mike Meyer
Thank you received: 6
Better tell us a model first.
regards
Mike
Sat, Jul 30, 2011 7:03 PM
hdroadkingc
Reply to Mike Meyer:
regards
Mike
Sorry. It's for a Cat 951C.
Sat, Jul 30, 2011 7:33 PM
rjh-md
Reply to hdroadkingc:
Cat always called for the same 30wt oil that was used in the desiel engine to be used in the transmission and steering clutches A 30wt oil with series 3 ,CD rated
or TO specs current
Final drives was changed from 30wt to 80/90 wt gear oil
Personally I would use 80/90 in final drives ,as I have seen a lot of final drive failures in 941 & 951 tractors when 30 wt was used
In a warm climate ,I would even use 140 wt ,and it was used by CAT for a while in all final drives
Sat, Jul 30, 2011 11:19 PM
