stearing clutch d82u
Showing 1 to 10 of 10 results
560 farmall
Send a private message to 560 farmall
I have a 1952 d82u and have finally started pushing trees. The problem is the left stearing clutch will completely release only part time. the brake will make it slip, but I'm sure this is hard on the brake not to mention my leg.
Was wondering if some one had any suggestion. I have looked in the manual
and the clutch removeal looks time consuming. Any help would be appreciated.
Tue, Jun 3, 2008 11:03 AM
Thank you received: 50
You could try going through the adjustment procedure but it seems you may be near the end of the wear limits or have a problem with linkage or thrust bearings.
Tue, Jun 3, 2008 9:23 PM
handhewn
Send a private message to handhewn
I operated my 2U like that for years before I learned about the adjustment you need to make from underneath the tractor. I finally got the right manual that showed how to adjust. I'd used up the adjustment from above and thought I could do no more. After adjusting from below I had more steering than I'd ever had and with far less effort.
Floyd
Tue, Jun 3, 2008 10:01 PM
Reply to handhewn:
Floyd
I can post the adjustment instructions if you need them๐Ÿ˜Š
Wed, Jun 4, 2008 3:16 AM
560 farmall
Old Magnet that would be great if you could send me the adjustment instructions. Thanks all for the help.
Wed, Jun 4, 2008 9:26 AM
Reply to 560 farmall:
This covers the 2U and earlier models.
Resolution is not to good on the first couple of pages due to the imposed limit on file size.
If you need clearer versions you will have to PM me your email address as posting pictures on PM's is not a feature provided.
Wed, Jun 4, 2008 10:24 AM
hellsgate_666
Send a private message to hellsgate_666
[quote="Old Magnet"]This covers the 2U and earlier models.
If you need clearer versions you will have to PM me your email address as posting pictures on PM's is not a feature provided.[/quote]
there is a shaft that runs the oil pump and back to the cable winch on the rear of the dozer could you tell me the best way to remove it from the dozer so i can pull the clutches the rest of the way out this is working dozer trying to get it back going as soon as i can will spend the money on a service book if some one can sell me the right one got one from ebay but it was not what is was suppose to be. thank you for any help u can give to me
Wed, Jul 24, 2013 9:46 PM
The shaft is trapped unless the transmission or the winch is removed.
D2-5J's, D6-9U's, D318 and D333 power units, 12E-99E grader, 922B & 944A wheel loaders, D330C generator set, DW20 water tanker and a bunch of Jersey cows to take care of in my spare time๐Ÿ˜„
Thu, Jul 25, 2013 1:11 AM
Pump stays but you will have to pull the winch (cable or towing) shaft and coupling to be able to remove the cross shaft assembly.
Thu, Jul 25, 2013 1:34 AM
English Al
Send a private message to English Al
the adjustment handhewn is referring to is called equalizer bar adjustment and can be accomplished by - first- check original adjustment up top by going to the s/clutch yoke and if the clearance between yoke and rear pressure plate is more or less than 1/2"+/- 1/16" it needs adjusting. Go underneath the backend of the machine and on transmission case immediately over the diagonal brace of the track roller frame you will see a nut- loosen nut ( only loosen ) go back up top and you will be able to move large operating lever to get your required clearance - don't forget to re-tighten nut underneath. Hope this helps Al ๐Ÿ‘‹
Thu, Jul 25, 2013 2:16 AM
hellsgate_666
yep we live out on a big cattle ranch so i am thinking i will take the winch of what a beast of a job but not as bad as removing the tranny i would guess..
again thanks for all of your help
Thu, Jul 25, 2013 2:31 AM
