Startup vid
Startup vid
JohnnyJ
Send a private message to JohnnyJ
Vid of startup after a 2 year nap.. also a broken injector return line drip.https://youtu.be/C1VNTIrTRJQ
Tue, Oct 25, 2022 7:39 AM
Kurt Bangert
Thank you received: 43
Nice! If I were you I'd pull that line, find the crack/hole, clean it up and solder it. A much better repair than hose. Gotta love the tree-pusher, that would do the job!
Thanks for posting
Tue, Oct 25, 2022 7:49 AM
JohnnyJ
Reply to Kurt Bangert:
Thanks for posting
I agree the original line fixed be best. Problem was that I had much problem (under statement) getting that line back into the pump. It’s the reason I’m thinking hose. Tree pusher.. ha yes attaching it I think doubled the tree toppling efforts ..
Tue, Oct 25, 2022 8:31 AM
Kurt Bangert
Reply to JohnnyJ:
Those lines can definitely be testing of one's patience. Thanks for posting
Tue, Oct 25, 2022 10:40 AM
Thank you received: 54
loctite/permatex make a fuel tank putty you could use that no need to remove it from machine.
Wed, Oct 26, 2022 9:25 AM
JohnnyJ
Thanks for posting
The line after leaving the 4 injectors elbows across the top front, elbows again downward. Watching the video and pausing like 30 seconds in you can see this line traveling downward before disappearing behind fuel tower tang shaft housing etc before re emerging where the drips visible. I’d sure like to see have access to the exact spot and try your advice. Thanks for following.
Wed, Oct 26, 2022 5:34 PM
