I've never laid eyes on a D9 that I know of, but if it's built like most CAT tractors, the clutch/torque converter will come out and get you into the flywheel to replace the ring gear. For a first timer and a helper with a suitable hoist and tools, I would say it is a good day's project.
Better figure on 2 or 3 days ,as there are some varables to this project .Are you going to remove the dash ,or fabercate a C to get acess to the flywheel with a hoist ? flywheel is recessed in the bell housing Do you have 2 3/4 fine thread studs about 6 or 8 " long to slide the flywheel on ? The 594 's I have worked on were the same as D9G ,having a torque converter ,and planatary gears in the fly wheel to remove . oil lines ,brakes pedal cross member bolted to the fenders ,and universal joint to remove .
After flywheel is out ,the new ring gear has to be heated ,and 2- 3/8 studes have to be screwed in the flywheel to slide the heated ring gear on to aline the bolt holes and locks
