Starter pinion adjustment.
fraser05
Send a private message to fraser05
On my d2 the pinion likes to kick out before I can get it started. End up having to hold the latch up to keep it in. I've adjusted the screws down to the point where they are below the cotter pins and still the same. I had it apart before putting back in I know the spring is ok but maybe weak? Might be worth replacing the spring???? Maybe pony is spinning too fast and try idling it down when starting diesel?? Any ideas? Thanks. Kyle
Mon, Jul 17, 2017 10:40 AM
Somebody has a Thread on here where they were having a similar problem?
Seems to me like they took it apart to analyze the individual parts and found the latches had a taper worn on them.
Sasquatch has an excellent YOUTUBE Video on the disassembly and repair of this part.
You may want to check it out.
Mon, Jul 17, 2017 6:21 PM
captainhowdy
Send a private message to captainhowdy
Reply to drujinin:
https://www.youtube.com/watch?v=vo0m1XBqdBY
https://www.youtube.com/watch?v=lKI3wTZU4AA
https://www.youtube.com/watch?v=5Xb9WzUxo5s
Mon, Jul 17, 2017 8:45 PM
fraser05
Those are great videos. Thanks for sharing. I've watched the last video before about bevelingbthe clutch discs. I did when I had the pony off and it works really well. Only problem while waiting on new nut locks to come in I got impatient and put the pony back on first. Oops!!
Tue, Jul 18, 2017 10:43 AM
old-iron-habit
Reply to fraser05:
Often I think we should have a Sasquatch must watch video sticky. They are great how to videos with every step clearly explained.
Tue, Jul 18, 2017 11:07 PM
