Starter issues
Starter issues
Showing 1 to 10 of 44 results
mikedell
Send a private message to mikedell
Hey everyone,
Im completed with my direct start conversion or at least I thought I was.
I have a new starter, which will turn the d4 over fine with the compression off, but when I switch it to run, the starter will not turn the engine over.
I have two 1000 cranking amp batteries hooked together which are both new, I have new cables, I have checked all my connections, I have good solid grounds.
Im lost, what could I be missing at this point?
Sat, May 17, 2014 5:06 AM
Thank you received: 77
Maybe the starter is a warranty return?
Sat, May 17, 2014 5:47 AM
mikedell
Neil,
Is there anyway to test these starters while it's still on the dozer to make sure its the starter that is the issue? It's looking more and more like it is indeed the issue but I would like to be sure before I remove this beast yet again lol
Mike
Sat, May 17, 2014 6:17 AM
Get it cranking, keep it cranking, then switch to run.
Does it crank or stall?
Hold the Crank button closed so the solenoid kicks in.
What starts getting hot / smoking?
Sat, May 17, 2014 6:20 AM
DPete
Reply to drujinin:
Do you have your batteries connected + to - to get 24 Volts ?
1962 D4C
Sat, May 17, 2014 6:24 AM
mikedell
Reply to drujinin:
[quote="drujinin"]Get it cranking, keep it cranking, then switch to run.
What starts getting hot / smoking?[/quote]
Tried this as well, started turning it over on in start position once it was spinning, I moved it to run position and it comes to a halt and the starter starts getting hot with a little bit of smoke.
mikedell
Reply to DPete:
Hi Pete,
No its a 12volt starter, I have + to + and - to negative, new cables and good grounds both from starter as well as for the batteries.
Sat, May 17, 2014 6:26 AM
DPete
Reply to mikedell:
Hi Pete,
[quote="mikedell"]Hi Pete,
No its a 12volt starter, I have + to + and - to negative, new cables and good grounds both from starter as well as for the batteries.[/quote] Hmmm, are you sure about the 12V? I have one of the first D4 factory direct start tractors and they were 24V, your symptoms sound like feeding a 24v starter 12 v
1962 D4C
Sat, May 17, 2014 6:32 AM
Reply to DPete:
What have you got for clearance between the drive gear and the flywheel ring gear. Seems like it might be to tight.
Sat, May 17, 2014 6:35 AM
mikedell
Reply to DPete:
Hey Pete,
yeah this was a aftermarket one I purchased on ebay while I was drilling the bellhousing for the the starter conversion. But now you have me wondering if the starter that I ordered was indeed a 24volt and labled as a 12 volt
rmyram
what size of cables? you say you have two 1000amp batteries, you'd need some pretty big cables to carry the full load amperage, i usually use 2/0 welding cable to make battery cables out of, anything less and they won't crank over on a real cold winter day.
also have you pulled the brush cover plate off, i have seen new starters come from the factory and two of the 4 brushes were not on the armature, the starter never did hav a lot of power or cranking speed. the brushes were stuck back in the brush holder, popped them down and into place and it was like a whole new starter.
Sat, May 17, 2014 6:36 AM
