sprocket pulling tools
Showing 1 to 7 of 7 results
mog5858
looks like I will be needing to build some final drive tools to pull a sprocket off a D6 8u-9U. can some tell me if I got the size of the foot about right?  pins look to be 3/4" inch puller legs are 19" long.  plan is to make them from 4330-V thanks  [attachment=74404]sproket foot size.jpg[/attachment]
Mon, Nov 27, 2023 12:49 AM
Mike Hudson
Send a private message to Mike Hudson
Mr Mog that looks just right. To get started. A little trial and error and you will have those sprockets on the ground. There is just something difficult about starting something especially if we haven’t did it before. Lot of luck. Mike Hudson
Sun, Dec 3, 2023 8:37 AM
mog5858
Reply to Mike Hudson:
thanks for your help. yes I know all to well about doing things that we haven't done before just cus someone else had problems doing it doesn't mean you'll have the same results but it always there in the back of your mind for sure.
Thu, Dec 7, 2023 6:57 AM
side-seat
Reply to mog5858:
I'd be interested in how that steel holds up to the tonnage.
Thu, Dec 7, 2023 9:30 PM
Thank you received: 227
Reply to side-seat:
Reminder -
The tonage is high when pulling sprockets, remember to leave the nut in place, stay on the opposite side of the tractor if possible so you have as much iron between you and the sprocket as possible. Any mishap sends shards of steel flying like fragments from a bomb!
Pulling the sprocket is only half the issue, it has to be pressed back on too, requiring more tooling.
CTS
Fri, Dec 8, 2023 2:51 AM
Reply to ctsnowfighter:
Reminder -
CTS
I believe you are pulling sprockets from wide gage D6?
The T-section of your item shown might be to thick if pulling narrow gage when your up against the final drive case.
Fri, Dec 8, 2023 6:43 AM
Mike Hudson
Well, if that be the circumstances then he will find that out as soon as he begins. Circular dimensions are difficult for the average without drawing skills and 3 d equipment. So it to early to can the project
Fri, Dec 8, 2023 8:47 PM
mog5858
yes I will most like be pulling wide or 9U as that's all that around hear for parts machines. the project cat is a 8U but that's the only one I ever seen up in Canada
Sat, Dec 9, 2023 7:53 PM
