Sprocket puller part number
Showing 1 to 6 of 6 results
Mschwartz
Where can I find a list of the sprocket puller part numbers?  I was able to purchase parts but not sure what I have or what I may be missing. I know different parts were for different applications but wondering where the part numbers could be found. Have the OTC 50 ton press, three long arms and bunch of miscellaneous parts. One is for 2 1/2-12 thread axle. Thanks, Mike
Tue, Apr 9, 2024 11:35 AM
Deebo
Librarian
Thank you received: 105
Depends what you’re working on. There’s a Service Tool catalog in the Tech Library. I’ve got a later version which I’m in the process of scanning which has more. And there’s a Dealer catalog that will be in shortly. Watch this space!
 [attachment=75856]7E6B7893-6C65-464B-B3F3-139879D60534.png[/attachment]
Tue, Apr 9, 2024 1:55 PM
Thank you received: 65
Reply to Deebo:
This should get you started......
 [attachment=75858]Sprocket-pulling.jpg[/attachment]
Tue, Apr 9, 2024 10:30 PM
bluox
OTC made their own final drive puller set that mostly would not use Cat puller parts  so you need to determine which puller you are dealing with.
Bob
Wed, Apr 10, 2024 12:29 AM
Mschwartz
I will attach some pictures of what I have. I am thinking that I may have an OTC set or part of. I can find a cat number on the 2 1/2 inch shaft adapter and the other cat numbers I think are for ring compressors. No easy to find numbers on rest of parts. Arms are 30 inches long for reference. Thanks, Mike
Wed, Apr 10, 2024 12:35 AM
Mschwartz
Reply to bluox:
Bob
[attachment=75859]4305EA75-D64E-4E07-A169-5460481A78A4.jpeg[/attachment][attachment=75860]A61C6ADA-6BBC-4310-8B9E-ABB2FAC8EE0D.jpeg[/attachment][attachment=75861]628B6BBB-CAEE-4E3B-A717-5D3667CD383B.jpeg[/attachment][attachment=75862]8759B494-7931-484E-ABD2-DF9820858AF6.jpeg[/attachment][attachment=75863]574C27FF-96D3-4F90-B947-138153E9D33B.jpeg[/attachment][attachment=75864]8411A6AC-E9F5-42CF-BBEE-3DA5A1F783F4.jpeg[/attachment][attachment=75865]E9C6A280-D2BC-4270-A2FF-70009BEAECCE.jpeg[/attachment]
Wed, Apr 10, 2024 12:37 AM
bluox
Reply to Mschwartz:
Yea that's a mostly OTC set ,I used to have a parts list for those but I haven't seen it in years.
I going to guess those parts have not been available for years.
On the plus side you have most of a set of clutch drive link bushings.
Bob
Wed, Apr 10, 2024 7:01 AM
