Sprocket press value
Showing 1 to 10 of 11 results
933scotty
Send a private message to 933scotty
Does any body have any idea what a set of press tools are worth? I found a set comes with 100 ton ram 75 ton ram a couple of hollow rams one electric hydraulic pump a manual hyd pump ( the round one) about 6 arms pins about 8 threaded adapters assorted puller parts and a bunch of assorted pullers and tools The guy is asking $6500. Is this a good price seems like a lot to me any opinions ? Thanks Scotty
Tue, Feb 24, 2015 7:06 AM
old-iron-habit
Is there any listing of what machines the press will work on with the supplied adapters. Will it work on sprockets? One could only surmise that the true value is how many times will it be used, and what is the value to hire the work out each time. Of course there is residual value when you are done and everybody has Cat friends that need a freeby to help keep it from rusting.
Tue, Feb 24, 2015 7:12 AM
Wombat
Donor
Reply to old-iron-habit:
If I lived near you, my recommendation would be for you to buy it, so I could borrow it.😖mile:
With the 100ton press, it sounds like the set to do all tractors up to and including D8K, providing it has all the adaptors and tubes etc. Usually a full pulling set if in good order does not come cheap.
Check to see what tooling comes with it. Is it a full set?
Tue, Feb 24, 2015 8:00 AM
d23j
Reply to Wombat:
If you don't want it I would be interested, regards Andrew
Wed, Feb 25, 2015 8:33 AM
933scotty
Reply to d23j:
Still looking for info!!
Sat, Feb 28, 2015 10:10 PM
josh
Thank you received: 14
Reply to 933scotty:
IF the components are in good condition, ( do the pumps and rams work properly or are they worn out, scored or leaking, needing rebuild) is well equipped and includes the adapters you need, (you need to post pictures and part numbers if you want help identifying parts) then I think the price is about average, not a low price or high.
Sat, Feb 28, 2015 11:41 PM
tctractors
Reply to josh:
I use this tooling at least weekly if not more, I have about every thing for CAT Komatsu Fiat etc with loads of spare items, I would advise you check out the cost of just a few simple items from CAT, the price asked for a 100 ton cylinder alone could well be up to $6500.
tctractors
Sun, Mar 1, 2015 12:28 AM
933scotty
Reply to tctractors:
tctractors
Still available
Thu, Mar 12, 2015 6:05 AM
AndrewJKC
Send a private message to AndrewJKC
Reply to 933scotty:
Still available
I know this is an old thread but on the off chance would this puller set still be available or would any one know where I could find a set doing final drives on a D7G and re bearing cross shaft the puller I have Access to is not the greatest and I’d like to have my own set thanks !
Sat, Dec 1, 2018 1:37 PM
DWC7
Send a private message to DWC7
Reply to AndrewJKC:
I have a puller cylinder for doing the D7G just did mine a few weeks ago and i have a couple cylinders. I dont want to sell the adapters etc. But i would sell the cylinder and a set of legs.
Let me know if you are interested. Only thing else you would need would be the dead axle adapter and pusher which both can be made easily.
OH and you need a pump. I have a pump as well but have not tested it. But i would if interested its a Cat hand pump.
Thu, Dec 6, 2018 3:03 AM
AndrewJKC
Reply to DWC7:
What would you want for the cylinder the pump and the arms ?
Fri, Dec 7, 2018 10:32 AM
