specs on scraper cable
vernier
Send a private message to vernier
Could someone tell me any specifications on cable for my #60 scraper ? I broke the ejector cable today, found a roll of 1/2'' cable with a working load of 4600 lbs. it has the wire center.Will this be O.K or do I need something else ??
Vernier
Wed, Oct 29, 2008 7:20 AM
Here us what was originally recommended:
Other will probably work but maybe not as long.
Wed, Oct 29, 2008 7:27 AM
vernier
Thanks OM The cable I got probably is not quality stuff and won't last as long as the original, but we are trying to beat the rain so I will give it a try.
Thanks again
Vernier
Wed, Oct 29, 2008 9:47 AM
Walt66A
Send a private message to Walt66A
Reply to vernier:
Thanks again
Vernier
Just make sure it is right hand lang lay. I knew a guy that got a good deal on cable, but it was left hand. It unraveled during use, and what a mess!
Thu, Oct 30, 2008 12:29 AM
vernier
Reply to Walt66A:
Yes it is the right hand lang lay, I made sure of that, got the new spool on today and everything re-threaded, what a job for one guy ! Hauled mud all day with no problems but I am keeping my fingers crossed.
Thu, Oct 30, 2008 7:25 AM
Reply to vernier:
Most important thing when releasing the clutches is not to let the bowl or apron drop or slam shut and unspool cable off the control drum, it will over lap and crush the cable on the drum, gradually release the brake with short movements back and forth, this will keep tension on cable while releasing.
Fri, Oct 31, 2008 8:58 AM
