Sparkplugs for pony
Sparkplugs for pony
vtstumpjumper
Send a private message to vtstumpjumper
Hey Neighbors,what would the number be for the sparkplugs on a 1934 Diesel Thirtyfive's pony, and are they the same for all ponies? Thanks much!
Sat, Jan 29, 2011 9:57 AM
What does it measure???? Most those old ponies used a 7/8 in. dia. x 18 tpi x 5/8 in. reach spark plug (originally a Champion #1 Commercial) current replacement is a Autolite #3076 (same as Model A Ford).
If it's really early it may be possible to run into tapered pipe thread spark plugs.
Sun, Jan 30, 2011 7:55 AM
vtstumpjumper
Thanks OM! I'm a step closer now. My pony turns but no spark so checking my mag is next.
Sun, Jan 30, 2011 7:29 PM
John from Fresno
Reply to vtstumpjumper:
OM,
I thought the ponies used the Autolite 386, Champion D16, 18mm plugs. The only thing that I have that takes the 7/8" plugs are the CAT 15's and 10's main engine.
Did they have pony heads that took the larger plugs?
Thanks,
John
Sun, Jan 30, 2011 9:27 PM
