Spark plugs D4 pony
Spark plugs D4 pony
Showing 1 to 7 of 7 results
molacr
Send a private message to molacr
Looking for proper spark plugs for a 1951 and 1952 Caterpillar pony Motor. I heard that resistor plugs are hard on Magneto motors. I have old cat parts book and spark plugs are 2A364 3. The one that are in there now are Autolite 124. Don't know if there the right ones. I found some D16 Champion but I believe they are too large thread. Like 18MM and I need 14MM thread. Can someone help. Thank You
Thu, May 30, 2019 10:49 PM
STEPHEN
From memory, the later heads take a smaller plug. Will look later if no one chimes in first
Thu, May 30, 2019 11:16 PM
A search for "pony spark plug" gets some good hits. Some recommendations.....
NGK 2910 (AB-6)
Autolite 386
Fri, May 31, 2019 1:30 AM
NGK 2910 (AB-6)
Autolite 386
any recommendations on plug gap?
Fri, May 31, 2019 6:51 AM
D4Jim
Reply to dpendzic:
I believe the book recommends .025 inch.
Cats Forever
Fri, May 31, 2019 10:46 AM
cheshire cat
Send a private message to cheshire cat
Should be champion d16 or equiv. 18 mm and are at a angle in the top edge of the head, maybe you have the later heads ? these have the plugs
in the middle of the head and stick straight out and are 14 mm thread champion L10 or equiv ... hope that helps ..
Fri, May 31, 2019 3:38 PM
Norm R2,22
Send a private message to Norm R2,22
Reply to cheshire cat:
When I put new plugs in, I went to NAPA. The only "Usual" plugs they had were resister plugs. They did have lawnmower plugs that weren't resister, so that is what I used. Seems to work fine. They also didn't have "Wire" wire. So a friend that does industrial boilers gave me some wire that he uses for the igniters. Super high temp with copper stranded wire. The mag should be happy with both low resistance wire and plugs.
Fri, May 31, 2019 10:42 PM
molacr
[quote="cheshire cat"]Should be champion d16 or equiv. 18 mm and are at a angle in the top edge of the head, maybe you have the later heads ? these have the plugs
in the middle of the head and stick straight out and are 14 mm thread champion L10 or equiv ... hope that helps ..[/quote]
Yes Plugs in the Middle. Thank You for your help.
Fri, May 31, 2019 11:53 PM
