Something else to work on
Showing 1 to 10 of 10 results
greyhead
Send a private message to greyhead
As most of you have read I have been adding to the ( needs repaired list ) as of late 😮
A model 22 has been offered to me the machine has sat [how long?] looks to be all there. steering/clutch feel good, over all it looks kinda rough ,rails look wore , bottom rollers are dry and flanges haven't been rubbing rail pin bosses yet🙄 side panels are MIA
So guys value? what do I look for
CAT 977K-11K, JD450-B ,JD690-B, IH TD-9 ,CASE 450-B JD750-E JD850-B
CAT D7-3T, KOMATSU P-68-8 LGP, CLARK 55A LOADER
CLARK MICHAGAN 85-C LOADER, CAT V60 FORKLIFT
And some old AC tractors
Fri, Jan 2, 2009 5:21 AM
OzDozer
Greyhead - A rough Twenty Two in the condition you describe seems to go for around $500-$750. It sounds like you better not look too hard, you might find EVERYTHING that's wrong with it. The list you provided doesn't excite me .. but, hey .. we've nearly all got rose-tinted glasses, when it comes to old Cats .. 😄
Complete is good .. sitting for long time is bad = stuck engine, most likely. Steering clutches "feel good" means nothing to me, unless I can work and run the tractor. Dry rollers = likely need to rebuild rollers. Rails look worn? .. then, they most certainly will be in poor shape, once you run the tape over them .. the tape doesn't lie .. 😊
Looks rough? That turns most people off, very quickly .. unless they find new undercarraige and a rebuilt motor, under the rough appearance .. an event that happens about as often as a solar eclipse .. 😄
Missing side panels? There's lots more tractors with missing side panels than there ever will be with them. They got torn off, thrown aside, and run over, at the first opportunity, most times .. 😞
Overall, I'd say you will be looking at a lot of work. Read - a near full restoration. You price in, the blood, sweat, tears, skinned knuckles, the $$'s, the parts hunt, and the long hours to get it back into nice shape .. then compare it, to buying one running, in good order .. and you'll find that a little above scrap value, is about the right value, as it stands.
Fri, Jan 2, 2009 9:41 AM
JasonPayneCrawlers
Reply to OzDozer:
Can you post some pics in order for all of us to be able to help you 😊
Fri, Jan 2, 2009 10:31 AM
greyhead
Reply to JasonPayneCrawlers:
Iam going over today for pics I got a digital cam/rec last night just for this
pictures are the only form of payment taken on this site😛 😛
So I had better stop type'n and start pay'n😄 😄
Fri, Jan 2, 2009 8:49 PM
greyhead
Reply to greyhead:
Well I went over to look at the 22 after nosen around the right side final had been welded up and showed signs of oil leaking😞 So I will have to find another🙄 thanks guys for all your input.
Its not what you know but knowing where to get your knowlege😄
Fri, Jan 9, 2009 3:44 AM
carlsharp
Send a private message to carlsharp
Reply to greyhead:
Hey before you just walk away, if you can get it cheap, and plan to work on another, a parts machine is always nice to have.
And you can sell the parts you don't need to the rest of us, to finance your project...
CS
Carl Sharp
Chino, CA
2xPV15; 22 2F; D4 5T
Various other oddball stuff
Vids: http://www.youtube.com/profile?user=carl4043
Fri, Jan 9, 2009 7:17 AM
greyhead
Reply to carlsharp:
CS
CS I thought about that very thing but 900.00 was as low he was willing to go. he stated scrap would bring more(that statment was like nails on a chalkboard)
Fri, Jan 9, 2009 10:47 AM
equipdriver
Send a private message to equipdriver
Reply to greyhead:
Call his bluff. Scrap is not worth beans right now. But some old guys just wont part with anything for a reasonable price.
Karl
Fri, Jan 9, 2009 11:47 PM
firekat
Send a private message to firekat
Reply to equipdriver:
Karl
I will argee with equipdriver call his bluff. Scrap metal here in Prince George,BC today is worth a whopping 40$ per ton. My 2 cents.
Firekat
Sat, Jan 10, 2009 2:36 AM
carlsharp
Reply to firekat:
Firekat
I'm with the last two-
Tell you what, make him a deal- you will pay him TWICE what the scrapper will, and YOU will personally haul it down there with him!
This of course assuming that the scap yard is within a reasonable distance, and scrap value figures out to about $120!!
CS
Carl Sharp
Chino, CA
Sat, Jan 10, 2009 6:35 AM
greyhead
Reply to carlsharp:
CS
CS,karl,firekat; you guys thats the best idea YET! Scrap yards thirty miles away tractor is another eight to ten The look on this guys face when I hand him the weight ticket and 240.0 in cash "PRICELESS"
I'll try this monday and reply back thanks Brad
Sat, Jan 10, 2009 10:17 AM
| Kingaroy, Queensland
