Solid front idlers?
Solid front idlers?
Showing 1 to 10 of 13 results
James Hayes
Send a private message to James Hayes
I have a 1955 D47U that I'm thinking of swapping front idlers on. Can anyone give me the diameter and weight of the solid front idler wheels? What is the main advantage of the solid front idlers over the spoked front idler wheels? I've heard the solid front idlers will help in grading. Is this true?
Thanks,
James
Sun, May 15, 2011 8:21 AM
D4C Charlie
Send a private message to D4C Charlie
It's not the solid part of the idlers that help although they keep sticks logs and the like out, the main advantage is the larger diameter as it puts more track on the ground. Smaller idlers give more of a roll forward or pitch which is quite frustrating when trying to do a nice grading job. I wil lcheck on the diameter of the disk type but I think it's 24 and 1/2 inch. Charlie
Mon, May 16, 2011 6:33 AM
James Hayes
Reply to D4C Charlie:
Thanks Charlie! How much would I need to lengthen my tracks? About a shoe or two??
Mon, May 16, 2011 7:25 AM
larslog
Send a private message to larslog
Reply to James Hayes:
The solid idlers came in both the larger and smaller size.I had the smaller spoke idlers on my 40A D4C and replaced them with the same size solid idler after a couple of spokes cracked out.For farming I prefer the smaller idlers as they allow for easier turning but for dozer work the larger size is better in my opinion.
Mon, May 16, 2011 1:14 PM
D4C Charlie
Reply to larslog:
Don't know about adding shoes. I will check with my manuals and see if they refer to adding shoes but I don't think so. How far out are your adjusters? Maybe someone knows more about this. Charlie
Mon, May 16, 2011 10:54 PM
ol Grump
I haven't seen anything about adding links with the larger idlers. The only thing I have seen was the difference between 4 and 5 roller track frames, 31 links for the 4 roller track frames and 35 (I think it was) for the 5 roller track frames.
Tue, May 17, 2011 8:10 PM
Reply to ol Grump:
The large diameter (25-5/8 in. O.D.) front idler requires a 32 link track group on the four roller frame....so 1 extra link is required.
Tue, May 17, 2011 9:00 PM
James Hayes
Thanks Men!
Wed, May 18, 2011 4:00 AM
bob
Send a private message to bob
Thanks Men!
The older D6,7,8&9's had idler bearing blocks with off set shaft bores so the same size idler could be mounted low for dozing or high for pulling. A detail you need to pay attention to when installing them.
Later Bob
Wed, May 18, 2011 8:23 PM
Thank you received: 62
Reply to bob:
Later Bob
Not to step on anyone's toes as I'm not an expert but the 9u's have a larger and smaller idlers with 40 or 39 link tracks.So do the bearing blocks also have a high and low position?
Ray
Wed, May 18, 2011 10:20 PM
Reply to Ray54:
Ray
Hi Ray,
Doesn't apply to the D6 "U" series.
Feature started with the D6c 74A - 76A series.
Wed, May 18, 2011 10:43 PM
