so i bought this D46U
Showing 1 to 10 of 34 results
captainhowdy
Send a private message to captainhowdy
[attachment=42441]170523_003.jpg[/attachment][attachment=42442]170523_002.jpg[/attachment][attachment=42443]170523_001.jpg[/attachment]
i finally got around to looking at the D4 i posted about a few weeks ago. the owner said it had only aprox 400 hours on it. after i looked at it i decided the previous owner must have put about 10400 hours on his D4 then replaced the pins and bushings and the sprockets along with some other stuff maybe including and engine overhaul. the blade lift needs some bushings to tighten it up and some packing in the cylinders and a few other things. get ready i am sure i will have a bunch of questions for the board.
Thanks for looking:israel:
I am going to try to keep this thread going with ongoing discussion as i find more questions so in the future maybe others can find answers to their questions in a single thread.
Wed, May 24, 2017 10:25 AM
d2gary
That's a nice looking tractor. It looks like it's ready to go to work.
Wed, May 24, 2017 11:07 AM
STEPHEN
Reply to d2gary:
I like it, but looks like like the sprockets were replaced with used ones.
Wed, May 24, 2017 11:39 AM
captainhowdy
Reply to STEPHEN:
I am just guessing but i think the sprockets,pins and bushings have about 400 hours on them since rebuild. i am pretty sure the owner didn't replace any rollers either but not sure. the rollers are all grease able type. where can i get the end for my grease gun so i can service them? what type of grease should i use?
Wed, May 24, 2017 7:14 PM
seyser
Reply to captainhowdy:
Good looking machine!
Wed, May 24, 2017 7:49 PM
captainhowdy
Reply to seyser:
I gotta get a button head grease gun for my rollers. is this the one? https://www.mcmaster.com/#button-head-grease-gun-fittings/=17rjnk4
Wed, May 24, 2017 8:08 PM
ag-mike
yes get 7/8" one. do u have the lube pump and know what to use in it?
[img]https://s26.postimg.org/oa2ajlvzd/SAM_0212_zps3ujfwhqo.jpg[/img]
Wed, May 24, 2017 8:14 PM
captainhowdy
Reply to ag-mike:
Thanks Mike!! I have an Alamite grease pump but we used it to fill guns with NO 2. my thought was to get the correct fitting and use corn head grease from Deere because i can get it in tubes.
Wed, May 24, 2017 8:45 PM
ag-mike
ok, just use the right stuff according to the operators and instruction book. i find lube chart right on except its agreed that atf be used in starting pinion clutch housing.
Wed, May 24, 2017 8:55 PM
captainhowdy
Reply to ag-mike:
Thanks again Mike. i didn't know about the pinion clutch housing. how do i check the level?? do you think corn head grease would be ok for the rollers?
Wed, May 24, 2017 9:00 PM
be careful using a cartridge gun as they can develop too much pressure and blow the seals out
I believe corn-head grease is close to 00 grade grease that is recommended
Booleroo 2025
CAFES 2025 TULARE, CALIFORNIA
| Tulare, California
| 34 Henty Hwy, Warracknabeal
Veerkamp Open House 2025
| Placerville, CA
