Sixty info
Sixty info
Showing 1 to 10 of 10 results
dadawg
Send a private message to dadawg
Hello, The Steam and Gas Threshing Show I belong to has a Sixty that needs some work. It starts and runs just fine but it needs assorted parts. It has been sitting in a shed for the past 20 plus years and gets pulled out and drivin maybe every 3rd or 4th year during the show. We are thinking of selling it to raise some money to repair some other equipment. I will be leaving for the show next week for 11 days. When I am there I will be getting more info on it and some pictures. Where are the serial numbers stamped on the Sixty?
Thu, Jul 15, 2010 6:46 AM
chriscokid
Here is a break down on the sixty model tractor
http://www.chriscomachinery.com/60serial.htm
Thu, Jul 15, 2010 7:35 AM
willwingo
Thank you received: 8
Reply to chriscokid:
The serial number appears on the brass data plate, the right front frame rail and on the flywheel (sometimes twice on the flywheel).
Don't put much faith in that list posted above- not very accurate.
Phildirt
Thu, Jul 15, 2010 8:18 AM
dadawg
Reply to willwingo:
Phildirt
Thanks for the info, this gives me a starting point.
Thu, Jul 15, 2010 8:28 AM
chriscokid
Reply to dadawg:
so what is not accurate? i would like for it to be very accurate.
I am not tring to be smart or claim to know it all, but I am compiling as much info as possible. I put those links up to the pages made so that someone as yourself can review them and hopefuly discover a problem so that it can be corrected. I would like to encourage anyone to help make the info very accurate so that the future generation of ACMOC members will have a very accurate source of information.
Thu, Jul 15, 2010 9:35 AM
willwingo
A couple of additional notes:
The serial number that is easiest to find is on the right front of the engine block just below the # 1 cylinder casting.
I have seen at least three styles of ID tags - one on the left side seat base, a different style on the right rear fender and another on the rear main casting above the drawbar.
Phildirt
Thu, Jul 15, 2010 9:23 PM
chriscokid
Reply to willwingo:
Phildirt
I have not discussed the location of the serial number on the page that was posted on the Sixty's. I did cover that information on the Best page because there has been some question about the differance in royality numbers and tractor numbers. So I am still wanting to know to what paticular info on the sixty page that you call inaccuate. I am only asking so that it can be corrected.
Thu, Jul 15, 2010 10:44 PM
SpragueM
Dadawg,
Which threshing show are you referring too? We are always looking for new shows to see in this area. Especially those with construction equipment.
Matt
Fri, Jul 16, 2010 4:48 AM
Atlas
Send a private message to Atlas
Reply to SpragueM:
Dadawg,
Matt
Hi chriscokid you have missed out one sixty no 3686A first of the production line in PEORIA 1927. Atllas ps i think you are doing a good information chart.
Sat, Jul 17, 2010 5:09 AM
chriscokid
Reply to Atlas:
Thank you Sir, I will get it added
Sat, Jul 17, 2010 5:11 AM
dadawg
Reply to SpragueM:
Dadawg,
Matt
[quote="SpragueM"]Dadawg,
Matt[/quote]
The show is the Lake of the Woods Steam and Gas Show. It is between Baudette and Warroad. Nine miles north of a little town called Roosevelt. Its a small show buy very hands on. Mostly farm and logging, not much construction. We have 5 full size steam traction engines, about sixty gas and diesel tractors. Steam powered saw mill, Blacksmith shop, Stationary and hit and miss engines, thrashing, Antique tractor pulls. On site primative camping.
Sat, Jul 17, 2010 9:29 PM
| Kingaroy, Queensland
