Side panels
Side panels
Showing 1 to 10 of 19 results
Mark Riendeau
Thank you received: 11
Looking for side panels (engine) for my 1959 70D.
Thu, Sep 5, 2013 12:29 AM
Mark Riendeau
No info. out there on these panels eh?
Sun, Sep 8, 2013 4:52 AM
Mark Riendeau
Reply to Mark Riendeau:
Does anyone know of an old 8T or 70D No. 12 that has good engine enclosure panels on them that the owner might sell?
Mon, Sep 16, 2013 5:34 PM
terrywelch_archive
I might have a set of panels for a 12, not sure. Will get some photos and send to expert grader man I know to see if they are the same. Then let you know.
Terry
Mon, Sep 16, 2013 7:11 PM
Mark Riendeau
Reply to terrywelch_archive:
Terry
Thank you. I'll check in from time to time and look for your reply. thanks again.
Sat, Sep 21, 2013 6:47 PM
Mark Riendeau
I can post pictures of these panels if that helps.
Sat, Sep 28, 2013 8:13 AM
terrywelch_archive
I was able to get out and look at the side panels the ends are very rough. I took a photo or two and will post here. I am not sure they are worth taking home.
Terry
Tue, Oct 8, 2013 8:20 AM
Mark Riendeau
Terry
I would like to see the pictures if you don't mind. Thanks for the help! Much appreciated.
Thu, Oct 10, 2013 5:55 AM
Mark Riendeau
The original part numbers are as follows: Right side 4F7544; left side 5F6782. There are two panels on the right side (with the same part #) and one panel on the left.
Fri, Oct 11, 2013 7:05 AM
Mark Riendeau
http://www.youtube.com/watch?v=HfCPfBUVbyw
In this video from You Tube, there are two old Caterpillar No. 12, 8T's plowing snow on Long Island N.Y..(circa mid 1990's) Both have the engine enclosure or door panels I am looking for. If anyone reading this and viewing this video knows of set or an of an old machine that has them..and may be acquired, please let me know. Even if they're in poor condition. I can use them as templates and build new ones. Thanks.
Mon, Oct 14, 2013 6:06 AM
old-iron-habit
Sent you a PM with a contact number where I seen a set for one side. I think they are the correct ones.
Tue, Oct 15, 2013 6:37 AM
