should I take the magneto off over winter or leave it wrapped?
Showing 1 to 7 of 7 results
BrianCamling
Send a private message to BrianCamling
I wrapped my magneto to keep rain off of it but now its looking like my working on the tractor will be done for the season.   I am trying to decide if I should just remove the magneto over the winter and store it inside or if keeping it wrapped would work OK. Northern IL so we get plenty of cold and snow. Any suggestions?
Thu, Nov 17, 2022 1:48 AM
Kurt Bangert
Thank you received: 43
I'd double bag it and call it good. I think that you'll be fine leaving it on.
Thu, Nov 17, 2022 2:09 AM
BrianCamling
Reply to Kurt Bangert:
Thanks. That's a good idea. I would like to leave it on because its not so easy to get back on and if the impulse drive gets moved then I have to retime everything.
Thu, Nov 17, 2022 2:15 AM
ChuckC
Send a private message to ChuckC
Reply to BrianCamling:
I wouldn't bag it. Any moisture that might be in there will stay in the gag. I would make some type of cover that would let air flow but keep any water or snow off of the mag. Just my 2 cents.
ChuckC
Thu, Nov 17, 2022 8:46 AM
Kurt Bangert
Reply to ChuckC:
ChuckC
Chuck makes a good point, you could cover the top and leave the bottom open the drain/breathe.
Thu, Nov 17, 2022 8:58 AM
BrianCamling
I was thinking about the moisture also. I will cut an opening in the bottom of the bag to allow air to circulate but not come in from the top
Thu, Nov 17, 2022 9:23 AM
Jack
A lot of farmers here used to cover a distributor with a rubber glove, a hole in each finger for the wires and where you'd stick your hand in left open and loose around the base of the distributor. The fingers were punched with a small hole to stick tight to the wire. It pretty much eliminated moisture problems from water, yet the cap and wires could dry out. Something similar should work on a magneto if it was big enough to cover. We also found that synthetic rubber inner tube carries electricity, so not quite so good.
Sat, Nov 19, 2022 12:37 PM
Thank you received: 55
Reply to Jack:
we cover most of or stationary engines with old tractor inner tubes split em on the inner radius and cut into segments yes you get carbon black over yourself as they weather. but it keeps the water off.
another method is grease lighly smear the seams with grease to moisture proof it some what.
Sat, Nov 19, 2022 12:54 PM
