Should I or shouldn't I?
farmerfred
Send a private message to farmerfred
Have a cousin with a 7E47A low horsepower tractor that is in good shape. All he does with it is dozer work. He gets no exhaust smoke whatsoever. He is wondering if he fueled it up to a high horse 7E47A, would it hurt anything? Just wondered if anybody had tried it and how it worked for them? I told him he should put a boost gauge on it for a before and after test and that would also tell him how much horsepower he had and how much of it he was using.
Thu, Jan 2, 2014 12:16 PM
Thank you received: 98
Hi, FarmerFred.
Re boosting the early 47A to later Hi-horse 47A 'grunt' capacity, it is my understanding that the turbos were different as well. I am pretty sure that the later units had a smaller bore turbo with a higher output and efficiency to match the altered fuel settings. These same turbos also had a larger exhaust outlet that connected to a larger stack to allow better exhaust outflow. I also vaguely remember a different air cleaner being fitted.
On the 'Love-That-Sound' side, they also had a somewhat deeper 'bark' than the earlier tractors.
Some of the more 'technical' people will likely chime in here shortly with possibly better info on this topic.
Just my 0.02
Thu, Jan 2, 2014 2:07 PM
djcat
Send a private message to djcat
Hi, FarmerFred.
Just my 0.02
I think from memory the dead axle was smaller on 160hp tractors.
Cheers djcat
Thu, Jan 2, 2014 4:02 PM
Reply to djcat:
Cheers djcat
Sounds like its running like it should. Turning it up and rolling smoke out the stack isn't the best for the engine, you just waste fuel and wash the cylinder liners and reduce engine life. The turbos are the same for the low and high horse just the elbows were changed for the dust ejector system for the air cleaner. The early sevens had the old style turbo like the 17as but the replacement turbo is the later style. Rpm for the low horse high idle is 1325 and the high horse is 1350.
Thu, Jan 2, 2014 8:00 PM
There is a difference in rack settings also.
Thu, Jan 2, 2014 8:01 PM
seiscat
There are several differences between low and high horse, most noteable is the much larger diameter dead axles. The air cleaners are also very different. If it ain't broke... Up the rack too much and and you risk finding the next weakest link. Sorry I did not notice this post sooner.
Tue, Jan 14, 2014 7:09 AM
