shop floor sealer
shop floor sealer
Showing 1 to 6 of 6 results
beaver-flat
Send a private message to beaver-flat
I'm finally building my new shop and was curious what experience was out there regarding floor sealer.
Floor is 7" of 5000 lb concrete. Trying to figure out what would be the best sealer for new concrete so it's easier to keep clean.
Wed, Sep 9, 2020 10:24 PM
Check with Sherwin Williams, they have special products for floors.
Wed, Sep 9, 2020 10:57 PM
Thank you received: 78
Trowel finish (like Lowe's and HD) is a first step, then apply sealer. Smoother surface makes it easier to keep clean.
Thu, Sep 10, 2020 5:20 AM
Steve A
I used a product 20 years ago called Cure Seal, it is applied immediately after the concrete finishers are done. Even now I can clean up a used oil stain of the floor with a rag and some gas.
Thu, Sep 10, 2020 8:03 AM
Djmayer
Send a private message to Djmayer
Reply to Steve A:
Be careful about the concrete dryness spec. The coating requires. We put down some really expensive epoxy on a new floor at work that pealed up in sheets because the floor hadn’t finished curing. Something like Steve A is talking about sounds perfect to me.
Thu, Sep 10, 2020 8:34 AM
epoxy coatings have to be low modulus(Flexible) so they wont expand differently from the concrete--we had a big problem on bridge decks until we swithched
Fri, Sep 11, 2020 10:32 PM
beaver-flat
Reply to dpendzic:
going with Tuff Seal J35, reccomended by out contractor
Sun, Sep 13, 2020 9:16 PM
