shop floor
shop floor
Showing 1 to 10 of 26 results
beaver-flat
Send a private message to beaver-flat
I'm about to push my old D6 into the shop so I can start working on it. Rookie question: will the grousers damage the concrete floor? If so, what have you guys used to protect it?
I have some 1" oak boards that I was thinking about putting down to roll it in on.😎
Thu, Nov 30, 2006 11:28 PM
Catmatt
Send a private message to Catmatt
Depends what kind of concrete your floor is made of. If it is high strength concrete, you'll be fine. Oak boards would never hurt though. have fun!
Thu, Nov 30, 2006 11:36 PM
Reply to Catmatt:
I would use the boards especially if you are having to shove it in or turn it on the floor at all. Straight in and back out under power will most likely still leave marks in the floor, so it depends how nice the floor is to start with.
Fri, Dec 1, 2006 1:37 AM
Kelly
I’d use the wood as well, or if you had some short pieces of old crasher conveyor belting would work also…we used it for crossing the Hi-ways years a ago and work well.
The thing is, the slightest nick in a fine finished floor will give your creeper trouble in getting around. I have seen some floors where you needed “Four Wheel Drive” on your creeper. 😞
Fri, Dec 1, 2006 2:34 AM
gwhdiesel75
Reply to Kelly:
I've used ordinary plywood sheets to cushion the impact of the grousers on the bare concrete. Doesn't have to be thick. GWH
Fri, Dec 1, 2006 4:09 AM
Jim Sixty
Send a private message to Jim Sixty
Reply to gwhdiesel75:
I'd use the boards even if you don't care so much about the floor, it seems like the machines don't sweat so much if they have wood or rubber separating them from the concrete.
Jim
Fri, Dec 1, 2006 5:19 AM
Rodney R
Send a private message to Rodney R
Reply to Jim Sixty:
Jim
Yeah, just use some boards. I used some 1/2 oak that we had cut, and it was extra/scraps. The grousers broke it here and there, but the floor is still OK..... also, if you need to cross an area where there is some sort of 'lip' - I'd set an extra board on each side of the lip, so the grousers won't hit that as well, or it'll chip off.
Rodney
Fri, Dec 1, 2006 6:26 AM
SpragueM
Reply to Rodney R:
Rodney
I use 2x8 or 2x10 and my d4 hardly dents it. Alot easier to replace than any floor. Even park on wood when in my dirt floored sheds. Keeps them cleaner.
Matt
Fri, Dec 1, 2006 7:29 AM
Jim A
Send a private message to Jim A
Reply to SpragueM:
Matt
At work we got truck tire retread stock to run on in the shop, rolls up when you don't need it.
Jim
Fri, Dec 1, 2006 8:07 AM
RKO
Send a private message to RKO
Reply to Jim A:
Jim
I just use old tires. The bigger machines I use Truck or Pickup tires. The smaller machines I use car or garden tractor tires. They cost nothing and will give to the shape of the floor and tracks. Can use the same tires over and over.
Fri, Dec 1, 2006 8:56 AM
OzDozer
Reply to RKO:
When I built my shop, I put old rail lines in the floor, three close together, each side, where the tracks ran .. and standing slightly proud of the floor.
Grousers are dynamite on concrete, with their "chewing"action as they reach or leave the floor. The rail lines worked good for the nearly 20 years I owned that shop.
Be aware that many shop floors are light on concrete thickness for dozer support. 4" is likely to crack, unless the pad under it has been specially compacted. In the construction of my floor, I compacted the gravel under it substantially, then used a minimum of 6" thickness, and high strength concrete to boot.
When the local Cat dealer went on a big upgrade in the late 1980's, they laid about 3 acres of concrete .. and it's 14" thick .. 😮
All the above suggestions are good. Conveyor belting is a good choice, if you can get it cheap, and easily.
If not, small car tires are the cheapest, simplest, and quite effective .. and plywood is quite satisfactory.
I guess it comes back to whatever is the most economically obtained local product.
Fri, Dec 1, 2006 9:43 AM
