Shims for 3306
Shims for 3306
Showing 1 to 10 of 10 results
pjcat
Send a private message to pjcat
Hi there!
I am rebuilding a 3306 engine from a D6C. The liners need to be shimmed and we are having a hard time finding shims in the size we need. I got the information that one has to counterbore the deck to the next thickest shim, which would be .030". I am trying to avoid the machining and was hoping to find shims in thickness .005" or .006" and .008" or .009" I was lucky and found some shims ind the .008" and .009" thickness, but they do not have the thinner ones. Anyone knows a source were we could find these shims?
Thanks a lot
Thu, Jul 17, 2014 1:36 AM
Thank you received: 43
According to my service manual they only come in 0.007, 0.008, 0.009, 0.015 and 0.030 " thickness, at least from Cat source.
Thu, Jul 17, 2014 2:37 AM
catsilver
Its a waste of time fitting shims without cleaning up the counterbore seat, its because of erosion here that shims are required, best do it right first time.
Thu, Jul 17, 2014 2:45 AM
pjcat
Reply to catsilver:
I will check more on the counter-bore condition. We wanted to do it the easy way, just add the shims, specially as the crank and cam is already in place. But now it looks like we have to machine this counter-bores first to spec.
Thu, Jul 17, 2014 4:54 AM
pjcat
Reply to pjcat:
old magnet: would you have cat part numbers for those shims? Thanks
Thu, Jul 17, 2014 12:26 PM
catsilver
Reply to pjcat:
You may not need to take the crank out, Cat dealers should have the kit to do this work just by stripping as far as liner removal, others can do it cheaper but usually with the bare block in their machine shop.
Thu, Jul 17, 2014 1:18 PM
Reply to pjcat:
Here is the entire spec....
Fri, Jul 18, 2014 12:31 AM
pjcat
Hey old magnet, that is exactly what i was looking for. 😊 A thousand thanks.
Now it was a breeze to order those at cat dealer. Before they didn't know where to find this information... kind of ridiculous.
Fri, Jul 18, 2014 3:13 AM
BW Farms
Send a private message to BW Farms
Reply to pjcat:
I am new to the forum and am looking for these shims for a 3306. I cannot view the full spec the Ol Magnet posted. Is there any chance somone could repost it?
Thanks,
Sun, Aug 23, 2020 7:34 AM
Thank you received: 29
Reply to BW Farms:
Thanks,
Hi BW Farms,
welcome to the BB.
Due to attachment space limitations we have to periodically remove scans from our old posts to post more for current subjects--soon due to change with the new BB.
Sun, Aug 23, 2020 8:24 AM
BW Farms
Reply to edb:
Hi BW Farms,
welcome to the BB.
Thank you ED B. I think this site is going to have a lot of good information.
Mon, Aug 24, 2020 5:05 AM
