shift fork replacement 955 loader
Showing 1 to 10 of 16 results
ecarter
Send a private message to ecarter
On a 955 track loader serial 12A6483 is it possible to replace middle shift fork through shifter hole? How do you remove top of transmission? There is a large pipe welded a few inches above trans that has been cut out and rewelded in past.
[img]http://img840.imageshack.us/img840/658/shiftfork1.jpg[/img]
[img]http://img696.imageshack.us/img696/2657/topoftrans.jpg[/img]
[img]http://img208.imageshack.us/img208/8828/pipetl.jpg[/img]
Wed, Sep 22, 2010 1:36 AM
Thank you received: 39
Covers going to have to come off. It's been off before, that's the reason for cutting and rewelding the brace so the cover can be removed without removing the loader....nasty job.
Wed, Sep 22, 2010 4:17 AM
ecarter
That's what I thought. I was just hoping someone knew a shortcut.
Wed, Sep 22, 2010 5:36 AM
catsilver
Reply to ecarter:
The cover comes off without cutting the bar off the loader frame, you have to strip everything off the top, then block the cover up a few inches and remove the steering clutch linkages ('rockers' and shafts) and brake band top sections from underneath it. The cover then comes out through the back. An awkward job but I did three in my early 'Cat' career.
Wed, Sep 22, 2010 6:52 PM
Reply to catsilver:
Hi Catsilver,
I now recall you telling us that before....but seems pretty common to axe the cross brace and replace. Guess some folks don't want to go to the extra time or expense.
Wed, Sep 22, 2010 9:54 PM
catsilver
Hi Catsilver,
I reckon it would take longer to weld the cross bar back in properly than to remove the cover as per the book, I was a Cat service engineer for 13 years, 7 of them field service (45 years total service) and would only ever use hot spanners as a last resort, they can cause more trouble than they cure.
It should take not much more more than an hour to remove the extra parts to get the cover out.
Thu, Sep 23, 2010 3:29 AM
Reply to catsilver:
I think that's part of the problem, what book are you referring to? Never could find any instructions on removing the cover on the loader.
Thu, Sep 23, 2010 6:26 AM
catsilver
I remember seeing an instruction but am not sure if it was an old servicemans reference book or a special instruction, it is all along time ago now, 1965 since I did the last one.
Thu, Sep 23, 2010 6:58 PM
Thank you received: 29
Reply to catsilver:
I have Form No 32225, Dated 5-56, Service Information for Caterpillar No 955 Traxcavator. It is an additional piece of Literature for the standard D4 so the Serviceman has full data for the Traxcavator section, however, it does not tell anything about removing the trans top cover with the frame in-situ or otherwise.
It tells how to remove the engine with the frame in-situ, work on the engine/s and master clutch in-situ, work on the hydraulics and lift frame etc, also how to remove the frame.
PS I also have Form No 32224-1, Dated 8-57, for the 933 Trax. it gives the same data as above also without any mention of the trans cover.
Fri, Sep 24, 2010 9:53 AM
catsilver
Reply to edb:
This is not a dream, the cover comes off without cutting lumps out of the loader frame, if we had done that in the dealership the service manager would have taken steps, big ones as he kicked us out on to the street!
The 933 doesn't compare, its a completely different assembly where the steering clutches come out of each side after removing the track frames and final drives.
The 933 shifter forks do come out through the gearbox top cover if you take the main clutch cover off as well and slide the rods out through there. You need small fingers and kevlar knuckles, I've still got the scars from 1966!
Sat, Sep 25, 2010 3:49 AM
Reply to catsilver:
Hi catsilver,
I don't think anyones disputing whether the covers can be removed without the gas axe....just that there has been a long time quest for some literature covering the task. At this point it doesn't appear to exist.
Sun, Sep 26, 2010 3:24 AM
