she no workie workie
Showing 1 to 7 of 7 results
mhar
Send a private message to mhar
I got the bright Idea to fix what wasn't broke and changed the hoses on the dozer. The hoses have a set of quick releases on both sides. The blade got locked up in the down position. I released the the quick release on the down side and raised the blade hooked the quick releases up and it worked for a time but has locked up again. Do the quick have a flow direction? or any suggestions would help
Tue, Jan 19, 2021 2:27 AM
How old and worn are the quick release connectors. As things wear (balls & collars) the valves may not open for adequate flow.
Tue, Jan 19, 2021 3:24 AM
crookedwrench
Send a private message to crookedwrench
We had the bright idea on our D2. Used a male end and a female end on each side. Did it carefully one at a time. Did the hydraulic rack at the same time. No way to hook them up wrong now. Works well. Even ran some long hoses from one side to a pull type plow. Is it possible that the hoses are not connected correctly??
Tue, Jan 19, 2021 5:56 AM
Thank you received: 78
Reply to crookedwrench:
That D2 would look brand new if it wasn't for the back of the fuel tank : )
Tue, Jan 19, 2021 7:51 AM
Shut the valve off n put 60 psi to er! that'll pop it out! lol
Tue, Jan 19, 2021 8:53 AM
nomorejohndeere
Send a private message to nomorejohndeere
some quick connectors are one way
don't ask how I know.........
Tue, Jan 19, 2021 10:06 AM
mhar
I turned two hoses on the down side end over end and I was off to the races. Thank god was able to do some work today with the machine Thank you gents
Tue, Jan 19, 2021 10:08 AM
Thank you received: 55
Reply to nomorejohndeere:
[quote="nomorejohndeere" post=225398]some quick connectors are one way
don't ask how I know.........[/quote]
that's called personal experience and development training
your family probably learnt some new words that day.
Fri, Jan 22, 2021 10:08 AM
