Setting the rack on 5J D2
Rob
Send a private message to Rob
I am working on a 5J D2. The problem is it is not getting fuel to start the main. I discovered that the injection pump housing was low on oil and I think that the cam has gone flat. I have a parts engine and I have removed the pump housing from it and I am going through it. I am also going to go through the transfer pump and replace the seals on it. I have all the manuals in electronic form and the one thing that I do not have to do the job is the rack setting fixture 1F7945 for setting the rack. I would like to check the setting as I have everything apart and it would be easy to do at this time. If I am unable to locate the tool I will just go with the setting it is at.
Is there another way of setting the rack or is this tool needed to do it?
[attachment=10661]37.jpg[/attachment]
Wed, Aug 31, 2011 10:00 AM
This has been discussed on a previous thread on a U series engine. Right off the top of my head I can't remember if it was a stationary engine or one in a tractor?
Wed, Aug 31, 2011 12:04 PM
Rob
Reply to drujinin:
I did a search and found some theads on setting the rack on the 5U series. It talked about a tool 3H1690 that you can replace for one of the pumps. The rack is different on the J series and the book I have does not say anything about the tool for any of the series but it is an old book. What I was wondering is if there is a different way to set the J series than what the book I have decribes.
I have also contacted a couple of sources that I have on getting the older tool and no one knows where one is located. I would also like to know if anyone knows of one some where in the Northwest that I might be able to use. If not then I will just use the setting that it is at. This pump housing came from a parts engine and I would like to have it checked before I put it on the cat while I have it apart.
Fri, Sep 2, 2011 11:10 AM
Reply to Rob:
There will be a U and my J at a Show this weekend. I'll have to take a look at the racks?????
Fri, Sep 2, 2011 7:17 PM
Reply to drujinin:
The 3H1690 tool replaces all those old fixtures that were used on the D3400, D4400, D4600 as well as the "U" models and others.
Fri, Sep 2, 2011 9:45 PM
