serial # read
serial # read
Showing 1 to 9 of 9 results
joseph
Send a private message to joseph
can and or how does one read a serial # on a machine.
Fri, Mar 18, 2011 10:46 AM
On CAT machines, in general, look for a small tag about 1 1/2" tall by 2 1/2" wide held on by a couple of rivets. Could be made of aluminum (most common), plated steel (wartime production), or maybe brass????
Usual places these may be found are on the engine block just below the head gasket line, usually near the pony motor controls and also on the rear of the bevel gear case above the drawbar support on a tractor. Other machines and attachments have different usual places where the same small tag is attached. Frequently if it's missing, the number will be stamped in the iron/steel between the rivet holes. In addition, some engines have the serial number stamped on the block just above the oil pan gasket near the fuel transfer pump.
Older than mid 1930's............. from what I can see, each machine is it's own special case. Ask on here and someone can guide you.
Fri, Mar 18, 2011 11:13 AM
joseph
sorry, Im not sure if I said that right. To clarify what I mean, I wanted to know if there was any way to interpret the year/make/and or the options associated with the serial number. for instance would the 14a2267 differ from a 14a6643?
Sat, Mar 19, 2011 8:16 PM
zootownjeepguy
Reply to joseph:
From what I know (and that's not much) there is no way to tell what options or accessories were on a machine from the serial number. Some tractors had the letters SP after the serial number to designate Special Parts but you don't know what "special parts" were installed. From the serial number you can tell the year of manufacture and that's about it.
You could also turn on the "bat signal" spotlight and wait for Old Magnet to chime in!👋
Rich Salvaggio
D2 5U9917
Sat, Mar 19, 2011 8:55 PM
Sasquatch
Thank you received: 5
Reply to joseph:
To my knowledge these old Cats only show the year they were manufactured, as in which number off the line they were in whatever year. They are unlike a vehicle's VIN number, where certain letters or numbers throughout the sequence indicate options, displacements, etc.
The only exceptions I can think of include various models of older Cats may have a "W" or an "SP" stamped after the serial number. The "W" meant wide gauge and the "SP" meant special parts were installed during the assembly line process, an example would be transmission gearing options not typically found on standard machines. This practice was abandoned sometime in the 1950's I think, or maybe a little earlier. Also some pre-1930 models were built in both San Leandro and Peoria at the same time, so the serial number prefix would show where it came from. Examples are the gas Thirty where an "S-***" number is a San Leandro built, and a "PS-***" number is a Peoria build. Same applies the the "A" and "PA" Sixty's, and the "L" and "PL" Twenty's.
Sat, Mar 19, 2011 8:59 PM
Thank you received: 52
Reply to Sasquatch:
The serial number info on early units is pretty limited as covered although I would add that some late 50's tractors had transmission group number tags added to the rear serial number tags.
The addition of engine serial numbers, engine arrangement numbers plus vehicle numbers didn't occur until about the early 70's and the advent of sleeve metering fuel injection.
Sat, Mar 19, 2011 11:03 PM
4x6zh itzik
Send a private message to 4x6zh itzik
itzik
8C 361
Thank you received: 12
Reply to joseph:
If you look through your parts book you can track down when changes were made by the serial number.
Sun, Mar 20, 2011 2:49 AM
A serial number just gets you a model/series and a number off the line. The later machines, especially engines, may have build codes etc as well as a serial number.
CAT did it like we do cow tattoos. Some folks want a lot of information on their animals, they have a system of letters and numbers so they can tell the birth year etc. All I want is each one to have a permanent, legible, unique number so I can go to a book and look up all that information and more besides.
Sun, Mar 20, 2011 3:09 AM
Thank you received: 37
Hi joseph,
the only way of getting close to a build date is to read the casting "NUMERALKOD"
Most major castings have this letter sequence usually near the cast on Part Number.
The Code translates as :-
N=0
U=1
M=2
E=3
R=4
A=5
L=6
K=7
O=8
D=9
Thus for Example :- UM-NL-AR becomes :- 12-06-54 or December six 1954
This is only approximate as castings can be broken and have been replaced. So, it pays to look up several KOD letter sequences and add about six months to the latest average sequences.
Of course buying the ACMOC Serial Number Reference Manual for Track Type Machines will get you the production year run serial numbers for each track type tractor model from 1925 up to 1960.
Other type machines you need to guess by the sequence KOD.
Hope this helps.
Sun, Mar 20, 2011 9:21 AM
