Serial number lookup
Showing 1 to 10 of 12 results
Remuda
Send a private message to Remuda
I found a few pieces of antique cat machinery when I looked at a cat 12 parts grader. I put the numbers in the caterpillar website for parts they didn't work. I have D 8 pony motor start dozer 5B6637 was on the block? I'm also trying to see if the parts grader cat 12 9k4612 so is comparable enough to mine 8T15407 that the parts would match ?
Paul
Wed, May 5, 2021 4:30 AM
bruce oz
Thank you received: 22
Hello , 5B6637 is a part number not a serial number , someone with equitant serial book will help the grader serial numbers
Wed, May 5, 2021 3:22 PM
Remuda
Reply to bruce oz:
Ok thanks I’ll look for one stamped on the block. I heard this site has manuals stored online for some of the equipment?
Paul
Wed, May 5, 2021 8:04 PM
gauntjoh
Librarian
Thank you received: 5
Reply to Remuda:
Paul
Hi Paul
Please see this thread...
NEW ACMOC Members Library - ACMOC Bulletin Board - Antique Caterpillar Machinery Owners Club
The library has just been launched and does have a range of Parts Catalogs for Graders. These are available to read on-line but not I'm afraid for download or printing out in full.
The library is located in the members area.
Wed, May 5, 2021 9:12 PM
Thank you received: 51
Reply to gauntjoh:
Hi Paul
The numbers cast into cast parts ARE NOT PARTS NUMBERS, adds a lot of confusion. I believe it has been stated they can be very close to parts numbers, but don't have to be.
Cat was good about stamping serial numbers into the base part under the serial number tags that are riveted on. The 40's and 50's era engines got the serial number near where the mag is mounted.
Wed, May 5, 2021 9:56 PM
Remuda
Reply to Ray54:
Ok thanks for all the information!
Paul
Thu, May 6, 2021 1:48 AM
Remuda
Reply to Remuda:
Paul
I couldn’t find the library only sources?
Paul
Thu, May 6, 2021 1:59 AM
josh
Thank you received: 13
Reply to Ray54:
Thu, May 6, 2021 3:21 AM
Remuda
Reply to bruce oz:
Is the equitant serial number book put out by cat ?
thanks
paul
Sat, May 8, 2021 9:34 AM
gauntjoh
Librarian
Reply to Remuda:
Paul
[quote="Remuda" post=228182"]I couldn’t find the library only sources?
Paul”
hi Paul, the library is in the members area of the main website not the Forum. We will shortly replace the old technical library heading on the forum with a link to the new library in the members area.
 [/quote]
Sat, May 8, 2021 9:47 AM
Remuda
Reply to gauntjoh:
Hi Paul
John
I found a few pieces of cat equipment that are going to scrap that I'm trying to save. I posted in the forum about it with  pictures. Any suggestions would be helpful. Basically it's a money deal I can't afford to buy all the equipment for scrap price and hire a lowboy to haul it. I just can't stand to see all those good machines and parts go to scrap. If there an equipment dealer that could buy them etc that would be great.
paul
Mon, May 10, 2021 11:49 PM
